TR2/3/3A Temperature Guage
Skidude
Member
Took the '59 TR3A to the farmer's market after church today. Just as we were arriving - a hose came loose and the Temp gauge shot to the right past 230 degrees.
No problem with the car - cleaned it up, tightened the hose back up and filled with water.
The problem is - the Temp gauge is stuck all the way to the right.
Any fix for this?
Have any of you experienced this problem before.
What do you guys recommend I do?
Geo Hahn
Just to be clear -- this is a stock capillary tube gauge and not some gauge using an electrical sending unit? Makes a difference in what I think happened (though on a cap tube gauge it is hard to explain).
CJD
Been there....
...done that!
I spent a whole day restoring and calibrating the temp gage. Then, the bone head that I am, I forgot to top off the coolant after changing the water pump. Same thing...the gage pegged right and stuck. It's a simple gage, and what happens is the needle gets pushed off the diaphragm. All you have to do is position it back on, but the catch is the gage does have to come apart to do it. I'll give you 2 options that I know of to fix it.
Here is option one. Remove the gage and the temp probe from the car, and fix it by the kitchen stove: (scroll down to post #100)
https://www.britishcarforum.com/bcf/showthread.php?94885-Instrument-Faces/page3
You can see the inside of the gage in the above post. It uses a brass bellows to measure ether pressure within the capillary tube. You have to bend the wire at the end of the bellows to re-engage the arm on the back of the needle. Once back in place, then you must calibrate the gage as described in the post.
Now, option 2. I did not feel like removing the entire capillary tube from the car when I pegged the gage...so I did it in place! I removed the screw from the back of the gage and pulled it a few inches outward so I could work on it. The chrome bezel can be turned by hand (with some effort) and it pops off, allowing the glass, seal, and instrument face to come off with it. That gives you access to the internals of the gage. Now, I removed the temp probe from the thermostat housing and freed enough capillary to bring it to the side of the wing. At this point I calibrated the gage by running back and forth with a pot of boiling water. The boiling water is 212 degrees at sea level. The temp here in Texas was 90 degrees ambient. So, by alternating between the boiling water and ambient I eventually got the gage set correctly by adjusting where and by how much the bellows contacts the needle arm.
I guess option 3 would be to do option 1 and mail the gage to Nisonger?!?
Dave Richards Temperature Guage Austin Healey 11
G Incorrect Temperature Guage: a fair assumption? Triumph 14
M Temperature Guage MG 6
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ā€˜dotsā€™ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature Gauges Again Triumph 5
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
