TR2/3/3A Tr3 fuel gauge sending unit
sp53
Tr3 fuel gauge sending unit is challenging my electrical understanding. I have two extra ones and I am trying to figure out which one might work best. One of them comes completely apart. However, on that one there appears to be a short because the hot lead shows ground with a continuity test back to the case. Again, the bottom assembly unbolts from the flange and I can see the little variable resistance coil dealie with the two arms coming out from the float linkage and just rubbing on the coil. I presume the problem is in the coil dealie shorting to the case. This is where I start showing my lack of understanding because if the arms are touching the coil is not the unit supposed to show some resistance or short? In addition to that, it looks like the whole unit gets submerged in fuel and why would that not cause a short. Even more problematic, how come the vehicle does not blow up if there is a short in the unit if it sparks?
Sp53
martx-5
The tank sender IS the grounding for the circuit. Hot goes to the gauge...through the gauge to the sender, and then the sender varies the resistance to ground.
Use an Ohm meter to check the sender as you move the arm up and down.
I would have to say that gas is not a very good conductor, or they wouldn't be putting electric fuel pumps in cars either.
S
sp53
Ok I kinda get what you are saying. The gauge is actually the ohm meter? If I take an ohm meter and put it on the hot post of the sending unit, It still should be insulated from ground right? I mean it should not show continuity?
Sp53
PeterK
The sender is really like a variable wire-wrapped resistor. As the arm moves up and down, the resistance (measured with an ohmmeter) varies. So measure across the terminal and the body of the sending unit with an ohm meter and you will see the value change. Select the "R" scale on the meter that shows a value change when you move the sender arm.
I am not an engineer but I did stay at a Holiday Inn once.
martx-5
The sender for the TR3 should have two terminals on it. One is insulated, and the other isn't. The one that is has the wire that comes from the gauge. The other just goes to ground. Just take an ohm reading across the two terminals and move the float. You should see the reading go from (IIRC) 0 ohms when empty to about 80 ohms full.
dklawson
All the information you've been given above should be helpful. The MGA Guru site is the best resource I've found on the web for the pre-voltage stabilizer gauges. Browse his site for information on checking and calibrating those early fuel gauges. It will be time well spent regardless of your comfort working on electrical things.
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
martx-5 TR2/3/3A TR3 Fuel Gauge Calibration Triumph 13
P TR2/3/3A TR3 Fuel Gauge Triumph 4
C TR2/3/3A TR3 Fuel Gauge Sending Unit Triumph 2
Geo Hahn TR2/3/3A TR3 Fuel Gauge Triumph 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
S TR2/3/3A old tr3 fuel pump Triumph 2
S TR2/3/3A TR3 fuel pump Triumph 16
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
M TR2/3/3A TR3 fuel pump Triumph 14
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
T TR2/3/3A Visiting the tr3 fuel tank again Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
R TR2/3/3A TR3 Fuel delivery problem Triumph 5
