TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3
Alvin
Member
My dash fuel gauge on my 59 TR3 quit working (after I took it apart and cleaned it up (oops)). The tank gauge works fine and gives me variable resistance depending on where the float is. I purchased what I "thought" was a TR3 replacement gauge that works, but it is for a TR4 and not a TR3 and it gives me readings that are way too high. My old original gauge is Jaeger FG2530/20 and my new one is Jaeger BF2206/00. What I am wondering is can I place the proper resistor between my tank and gauge that will make it work properly? Has anyone done this before? Thanks ..................AL
DNK
Alvin, who did you buy the incorrect one from?
TR3driver
Great Pumpkin - R.I.P
Nope, can't be done. The TR4 sender and gauge work 'backwards' to the TR3. The TR4 gauge reads "full" for (nearly) zero resistance, while the resistance of the TR3 sender goes up when the tank is full.
You could possibly build a little electronic circuit that would translate, but it seems a lot simpler to find the correct gauge.
BTW, the TR4 gauge is sensitive to charging system voltage, so you'll also need a voltage regulator/stabilizer to make it work properly.
A
Alvin
Member
Thanks Randall. Guess I have to scrap that idea........but it "seemed so brilliant"! I bought the gauge on E-bay and I will resell it. It is a nice gauge.
TexasKnucklehead
I ended with a TR4 fuel gauge for my TR3 too. I had trouble getting the proper sending unit for the gauge, and gave up after several obvious incorrect attempts.
(Gauge number BF 2301/00)
Since I already have the voltage stabilizer for the temperature gauge, I opted to find a suitable sending unit. I plan to use a SunPro 'universal' CP7583 fuel level tank sender. I had to swap the tank mounting plate with the original one, but the float arm was adjustable, and the resistance is close to what it should be. Empty shows empty, and full shows full -the accuracy of the rest isn't that important to me. I can't tell how well it works in practice, until the car is finally on the road. But the float at the bottom of the tank says empty, and at the top shows full.
My notes say TR3 empty=2ohms full=85ohms TR4 empty=240ohms full=30ohms.
Hope this helps.
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
KVH TR4/4A Two TR4 Trivia Questions: Fuel Gauge and Shocks Triumph 2
J TR4/4A Auto Meter Fuel Gauge for TR4 Triumph 1
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
B Triumph TR4 replacement fuel tanks Restoration & Tools 3
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
A TR4/4A TR4 Fuel Pump Triumph 5
Kirk_Fisher TR4/4A Fuel mileage TR4 Triumph 17
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
KVH TR4/4A TR4 Fuel Pump Triumph 9
SCguy TR4/4A Cork gaskets for TR4 fuel pump glass bowl Triumph 7
M TR4/4A TR4 Fuel Pump Rebuild Triumph 3
D TR4/4A Electric Fuel Pump for TR4 Triumph 5
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
M TR4/4A TR4 Fuel Delivery Triumph 0
SCguy TR4/4A TR4 fuel line? Triumph 5
SCguy TR4/4A Fuel Tank, Fuel line question, TR4 Triumph 7
T TR4/4A Fuel line on TR4 Triumph 6
T TR4/4A Fuel tank on TR4 Triumph 0
J TR4/4A TR4 Fuel Line to Carbs question Triumph 2
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
Alan_Myers TR4/4A Fuel tank sending unit - TR4 Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
