TR4/4A Fuel tank sending unit - TR4
Alan_Myers
Hi all,
Does anyone know the operating range (ohms, I think) of a TR4 fuel tank sending unit? I'm wondering what, if any, aftermarket fuel gauges might be used with it.
Thanks!
Alan
Geo Hahn
I saw one item on a Stag forum that said the TR4 fuel gauge is zero to about 60-65 ohms. Actually I wouldn't be surprised if it was really 0 - 70 ohms, same as a TR3 (I realize that the gauge is slightly different due to the 10V voltage stabilizer).
spbvmb
Member
Alan,
I finially can contribute something to this forum. I feel like one of the guys. I just went through this. The ohms are from 12 to 250 + or-. The units on e-bay or from Victoria British are the same. They work in reverse and have an ohm rating from 10 to 100 so only cover 2/3 of the gauge, even if you jury rig them by reversing the float. As usual Moss is the most expensive but it works. Thanks for the opportunity to contribute. Phil Brooks
BoyRacer Fuel Tank Sending Unit Austin Healey 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
rjc157 fuel tank sending unit Austin Healey 4
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
bugedd Fuel tank sending unit Spridgets 18
M Tell me I need a fuel tank sending unit Spridgets 21
M Smiths Fuel Tank Sending Unit Austin Healey 3
W Wiring to BE fuel tank sending unit Spridgets 4
M Smiths fuel tank sending unit Triumph 1
G Fuel tank sending unit gasket leaks.....quick fix? Triumph 5
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
H Fuel Tank Sending Unit Float Austin Healey 11
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
