SD Bugeye
I’m having fueling issue
ive discovered that the pickup tube in the tank draws air when tank reaches approx 3 gallons from full.
what is on that pickup?
the fitting is out the side wall of the tank facing the front of the car.
im concedering drilling it thru and putting a tube turned down toward bottom of tank passing thru the fitting with a crush seal..
there does seem to be anything moving around in the tank
anybody know what the situation is on that side of the tank is there a screen could I have knock off the pickup tube with my ... sprited driving?
