Ninety nine and a half just won't do....
G
Ya gotta have a hundred percent of the new/old paint off the floorboards before you go back with the new stuff.
My fingers hurt so bad I may never be able to pull a tooth again.
T
Tinster
Bill,
If the 1% remaining is tightly bonded,
why kill yourself to remove it?
Can't you kinda think of it as a pre-primer?
d
Brosky
If he is, I'm glad he's not pulling or working on any of my teeth. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
T
Tinster
Bill,
get a gallon of xylene.
After a minute or so- you won't care
(or be aware) of how long it is taking you.
On second thought, a bad idea to suggest to dentist.
Ya just might start pullin' out yer own teeth.
keep the faith.
d
philman
hey, isn't that the title of an old wilson pickett song????
G
Razor blade, CutZit, Martin Senour Paint remover, wire brush, pick, and a lot of profanity.
DNK
Bill find some of this ,lots of fresh air
Twosheds
Yes, it removes the whole aircraft, not just the paint!
Harry_Ward
I use to do everything by hand sanding and wire brushing as well until I noticed my fingernails were gone. Then I went (Airpower) air and power tools. Bill, you should have lots of these attachments laying around the office.
NickMorgan
Bill,
I heard that 3M seam sealer is very good at removing paint. Oops, sorry!!
sp53
I think what we have here Bill is a case of Platonic idealism coming to life. You are projecting your own perfectionism into the vehicle, hoping the vehicle will immortally live. Of course the vehicle is actually a recreation of you in a quasi- perfect form. Your lack of immortality is propelling into removing every last drop of imperfection, so that you will live forever as the vehicle. Paint that thing Bill and put some rugs in it. The vehicle is already going to out last you by twenty years.
Sp53
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
T 1933 Standard Little Nine Carburetor Other British Cars 8
jmwuva05 1958 nine stud windshield Spridgets 18
Baz Nine hours straight Midget work! Spridgets 11
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
F TR2/3/3A back half to chassis questions Triumph 105
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B BJ8 Half-Shaft Oil Seal Austin Healey 5
SD Bugeye Half capacity of the fuel tank Spridgets 10
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
Boggsy64 MGB Half shaft question MG 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
G Half shaft removal Triumph 3
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
ScottTR6 Half shaft replacement Spridgets 7
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
T Half way? Triumph 189
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B 3.9 Diff/half shaft/spline question. MG 2
J Spitfire Spitfire Half shafts Triumph 3
F Removing Axle Half Shaft [Tube Type] MG 4
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
D Stag Stag half shaft removal Triumph 6
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
