Meyer'sTR3
Was cruising along and then the engine just stopped. Like right now...as if the key was turned off. I pull over to side of road, try turning the engine over and it fires up for a couple of seconds and dies. After that no more firing up. I suspect the fuel pump has just died. Everything else seems good. I pull off the fuel supply hose just before the carbs and turn the engine over and get nothing through the fuel line. So....I am concluding that the fuel pump died. So what now? Do I order a rebuild kit, or just purchase another fuel pump. I don't mind spending the money for a new pump if it will save me the hassle of rebuilding this one. If y'all think it is better to just rebuild, could someone who has done this give me step by step instructions on the rebuild process? I have already removed the original pump and pulled out the diaphragm. I don't see anything wrong, but I suspect that something is amiss. I tried to reconnect the diaphragm pin again and am having trouble getting it locked back in. Anyway, I would appreciate any info from those who have gone through this already. Rebuild? How?...Get a complete new one? From who? Just go electric? What type? ect... I know you experts are out there, and I want to hear from you!! Much thanks in advance.
