TR2/3/3A TR3 Fuel Pump Check Valves
Mkutz
Merry Christmas All!
I've been having a recurring problem with my TR3 fuel pump check valves; the first set I used would pump no fuel at all, then the second set lasted about one month and now pumps nothing at all. I saw recently someone else was experiencing a similar problem -- anyone know where to get correct valves?
Brosky
I just ordered some kits for some TR6 pumps that I'm doing from Tom at his business, Antique Auto Parts Cellar, 6 Chauncy St., South Weymouth MA 02190 781-335-1579.
I was given his info by another forum member and I find him to be extremely knowledgeable and he only deals with top quality parts that will with stand the new fuels. No website for him and NFI for me.
You will need the 4 digit number (or any numbers) that are on the pump.
TRopic6
I rebuilt my pump in July (bad diaphragm) and noticed the new valves used a rubber 'flapper' where the original ones were a hard disc. One of my originals didn't seem to seat fully so I only used one of the new valves.
I'm having fuel delivery problems when the car idles for awhile in hot weather (this is Hawaii). Maybe the low-boiling fuel we now have (ethanol) is creating more backpressure that the new check-valve can seal against.
If this is becoming a common problem, I'd like to soak one of the new checkvalves in fuel to see if the rubber flapper distorts...only there's too much Christmas upheaval for me to find where I put the other valve. Anybody else want to try it?
Mele' Kalikimaka!
Jeff
2xTR6
angelfj1
Mkutz said:
Thanks for the lead Paul. I'll reach out to him tomorrow to see if he has a solution for me. Thanks!
Mkutz: I'm trying to find a replacement "black" diaphram for the 3A. See below.
The diaphrams being sold these days are red and are not correct. If you are able to reach Tom I would be grateful if you ask him about this.
Many thanks and Merry Christmas
frank
TR3driver
Great Pumpkin - R.I.P
The kit I got from TRF just a few weeks ago has a black diaphragm; proper poppet type valves; and also includes the secondary seal for the shaft (NLA for many years) as well as a new screen and seal for the sediment bowl. P/N RFK1400.
martx-5
That looks like the same kit I got from TRF maybe a year ago, as they were the only ones offering the secondary oil seal. Hopefully it has all the proper parts in it, as I only have about three hours on the engine. So far, so good. We'll see in the spring time.
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
S TR2/3/3A old tr3 fuel pump Triumph 2
S TR2/3/3A TR3 fuel pump Triumph 16
M TR2/3/3A TR3 fuel pump Triumph 14
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
E TR2/3/3A tr3 fuel pump spacer Triumph 6
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
RedTR3 TR2/3/3A TR3 Fuel Pump Removal Triumph 13
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
martx-5 TR2/3/3A TR3 Fuel Pump...Rebuild or New Triumph 6
S TR2/3/3A TR3 fuel pump rebuild Triumph 10
jsneddon TR2/3/3A TR3 Fuel Pump Gasket Triumph 23
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
