TR2/3/3A Not all tr3 fuel pumps are built the same
sp53
Not all tr3 fuel pumps are built the same. The one I am working on right now has those 2 valves put in with crimps in the pot metal and not screws also the there is a center seal that is crimped in. Are these pumps rebuild able? I was thinking to clean it up the best I could and put the new diaphragm in and call it ok. Perhaps I could gently file out those 2 valves, but how would I seal them and attach them. Ideas anyone?
Geo Hahn
Yes, I have seen a variety of systems including the staking and in another a little butterfly-shape piece of metal with the screw through the center.
I have had a check valve fall out but I do not recall ever having one that failed to work - so I do not generally mess with them when rebuilding a pump.
One other difference among pumps is how the shaft that the lever moves on is secured. On some it has a clip on each end - a good method. On others it simply sits in a slot and is captured when the pump is bolted to the block - also good. The one I have had trouble with is a pin that is just a press fit. There I had one where the pin would walk out over time, releasing the lever and parking the car.
charleyf
I as well as George have rebuilt some pumps without changing the two crimped in valves.
On the pump with the pressed in pin , I took two small pieces of sheet metal( like about 1/8"X 1/4") and JB Welded them on each side of the pin. Still working. This after I noticed that the pin was moving.
Charley
trrdster2000
A little bit of information on the spring. Use your old one. Even if you buy a new pump, change out the spring. The new ones are heavy duty and will give you 5 PSI, Not good.
Wayne
S
sp53
Good deal I was hoping someone had left those 2 valves alone and had some success. I am thinking now about a good way to cosmetically clean the top piece that holds the valves. Perhaps masking tape on the bottom to keep the crud out or maybe the masking tape on the valves and bolt the 2 half’s back together then clean with solvent or and steal wool
Steve
charleyf
You do not usually have any crud on those valves. Cleaning with carb cleaner spray would be one way to deal with them in place.
Charley
S TR2/3/3A Tr3 fuel pumps in the mountains. Triumph 11
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A old tr3 fuel pump Triumph 2
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
S TR2/3/3A TR3 fuel pump Triumph 16
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
M TR2/3/3A TR3 fuel pump Triumph 14
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
T TR2/3/3A Visiting the tr3 fuel tank again Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
R TR2/3/3A TR3 Fuel delivery problem Triumph 5
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
E TR2/3/3A tr3 fuel pump spacer Triumph 6
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
M TR2/3/3A TR3 Fuel Pump Check Valves Triumph 7
