Fuel Sending Unit
TulsaFred
I cleaned up my old Bugeye sending unit, getting ready to install it in a new field tank.
I'm assuming this is an original Smiths unit. Don't know if it works or not.
How can I test it while on the bench?
Fred
nomad
I would think that just connecting a VOM meter to check its resistance as you move it slowly through its range would do it. Visually it looks pretty good. I think that the major problems with them is the lever not making contact or the resistance coil having a break in it. May also have some continuity issues at the terminal end's.
Kurt.
Jim_Gruber
0 Omhs at one end and 80 Ohms at the other.IIRC.
smaceng
I always connect a ground wire from the case to one of the bolts holding the gas tank. This assures a good ground.
Scott in CA.
Looks like an original unit.....some of the aftermarket ones are junk!
The aftermarket units have a very coarsely wound coil.
TulsaFred
TulsaFred
Thanks, I'll put an ohm meter across it and move the float and see what I get.
A ground wire sounds like a good idea, too.
BoyRacer Fuel Tank Sending Unit Austin Healey 3
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
rjc157 fuel tank sending unit Austin Healey 4
R Fuel sending unit Austin Healey 4
V Fuel Gauge Sending Unit Austin Healey 3
C TR2/3/3A fuel sending unit Triumph 9
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
R TR2/3/3A TR3A Fuel sending unit Triumph 3
bugedd Fuel tank sending unit Spridgets 18
E BE Fuel Sending Unit Wire Spridgets 0
stretchit2 Fuel Sending Unit - Short? Austin Healey 16
M Tell me I need a fuel tank sending unit Spridgets 21
AUSMHLY fuel sending unit float position Austin Healey 16
bugedd Fuel Sending unit Question Spridgets 6
G Fuel Gauge - Sending Unit Question Austin Healey 20
T TR6 tr6 fuel sending unit Triumph 5
M Smiths Fuel Tank Sending Unit Austin Healey 3
W Wiring to BE fuel tank sending unit Spridgets 4
W Wiring the fuel tak sending unit Spridgets 2
6 fuel sending unit Triumph 3
M Smiths fuel tank sending unit Triumph 1
TimK Erratic Fuel Sending Unit Austin Healey 10
AUSMHLY Who makes the best fuel sending unit Austin Healey 4
AUSMHLY Fuel sending unit Austin Healey 1
boxofparts MGB 79 MGB Fuel Level Sending Unit MG 6
T Fuel sending unit Triumph 34
S TR2/3/3A Tr3 fuel gauge sending unit Triumph 6
G Fuel tank sending unit gasket leaks.....quick fix? Triumph 5
philman fuel sending unit MG 1
C Fuel Level Sending Unit MG 4
philman fuel guage sending unit MG 19
B Fuel Sending Unit Float Triumph 14
bighly Fuel Sending Unit Leakey Float Replacement Austin Healey 9
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
C TR2/3/3A TR3 Fuel Gauge Sending Unit Triumph 2
H Fuel Tank Sending Unit Float Austin Healey 11
Alan_Myers TR4/4A Fuel tank sending unit - TR4 Triumph 2
kindofblue Front Dust Caps Problem & Seized fuel Sending Unit Triumph 9
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
J Fuel gauge sending unit Austin Healey 2
bighly Fuel level sending unit leak Austin Healey 1
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
