TR6 tr6 fuel sending unit
TexasKnucklehead
So my gas guage was reading 3/4 when the tank was full, and 1/2 when it was empty. After a little testing, I got a new sending unit, removed the tank, replaced the sending unit, replaced the dried rubber hose below the tank, and the fuel filter and those hoses as well as the filler neck gasket that hed been leaking for years (with replacements purchased 3 years ago). Now it reads empty with less than a gallon in it. Don't ask about the gas bath or the clean spot in the driveway, but be sure the hose size is 5/16 not 3/8.
Anyway, after it's all back together and in the garage, I have to know what's wrong with the old sending unit. First, the float is about 1/2 full of gas. Second, the downward travel is limited by something rattling inside the cover that turns out to be the top of the rivet that is used to hold the phonelic card to the body. The rivet rusted in half! I might have learned from this to use 'better than' parts when replacing, but realize this may have already been beter than original. In the picture you can see the black spot between the unit and float that is the top of the rivet. The bottom rivet is OK.
DNK
Ya needed to replace the float with the Ford one ala those Conn. boys
SkinnedKnuckles
Yeah. The float on mine also had liquid in it - I assume it was gas. I debated whether or not to drain it, but ended up putting it back in as is. That was 4 years ago.
Had the opposite problem with hoses - someone had fitted 1/4" hose. The 5/16" isn't quite as restrictive.
dklawson
The Ford part is COAZ-9202-B. It's brass, it's nice, but not as cheap as it once was. Expect to pay about $10 for one. However, since it sounds like you now have a new sending unit, it's likely to be years before you need a new float.
I now have the Ford float in the project Spitfire. It's a little bigger in diameter than the Smiths float but fits the arm very well.
Picture Here:
Click here!
DNK
This
dklawson
Thanks Don! I was having trouble getting the link to work.
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
