TR6 76 TR6 electric fuel pump?
wangdango
Would like to do away with the stock pump, (it needs a rebuild, and as the car does not get much driving, tends to run the battery down). SO, want to make a plate to block off the hole and install a electric Facet pump. Any one done this? Ideas, on location, wiring, etc?
JImEgan
Install pump near and below tank. Electric pumps push fuel better than they pull. I am putting one one my GT6. Making block off plate out of aluminium and am going to attach a bi-pass regulator at that location. I am using a bi-pass regulator to help keep vapor lock down. install an inertia switch to cut off pump in event of accident.
Jim
R
RonMacPherson
hot rod shops sell chebby block off plates, fit on the 6 engine..
BobbyD
Frank Fischer makes a plate that's a perfect fit and doesn't cost much.
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
R TR6 TR6 Electric Fan Triumph 10
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
M TR6 TR6 electric fan Triumph 11
Tullamore TR6 TR6 Electric Fan Triumph 6
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
