TR6 Mounting location for electric fuel pump on TR6
Gliderman8
At the end of October, I purchased a Facet electric fuel pump to install on my TR6. Its been a cold winter and I didn't feel like working on the install in an unheated garage. Today is the day that I decided to install the pump as the temps are in the 50's!
Just where do you mount the pump?
The base of the pump is too wide to fit the frame... of course I could trim the base of the pump if that's whats required.
If anyone who has mounted the Facet pump can post a few pics of the mounting and location that would be great.
Thanks for any help!
justin_mercier
I dont have a facet pump, but I do have an electric fuel pump that I just recently mounted. Electric pumps like to be pushers rather than pullers, so you should mount it close to the tank. I mounted mine just under the rear shock tower on the side of the frame.
Gliderman8
Gliderman8
This one.....
DNK
Any reason you plan on changing to an electric?
dklawson
Correct me if I am wrong, bub didn't the injected European cars put their pump low in the left side of the boot near the tank itself?
With those "brick" Facet pumps, pay attention to their suggestion to mount the pump at an angle. It was explained to me that the internal bits of the pump continue to seal better/longer if the moving parts operate at an angle off vertical.
Gliderman8
Gliderman8
I'm installing the electric only because of perceived reliability? I mean the mechanical pump was rebuilt when I completed the car and is doing OK but I worry about it failing one day so therefore I thought I'd install the electric.
As for mounting on an "angle" this is what the instructions say:
NOTE: It is recommended that the outlet of the pump
be at least 45º above horizontal. This will
allow any vapor buildup to easily pass
through the pump.
DNK
Elliot- I'd keep the mech one if it is doing fine and then wire the electric as a back up when needed
Those Facets can be loud
Gliderman8
Gliderman8
Don- are you saying to run separate fuel lines from the electric to bypass the mechanical pump?
Doug-As for mounting it low in the boot, I just had a look in the boot area.... the bottom of the tank has a fitting that goes through the body. If I mount the pump in the boot, I don't see how I would be able to connect the inlet side of the pump from inside the boot.
DNK
No, lots of people have set up the electric as back up with just movement of lines.
Somebody will have to chime in on the how
donbmw
I have had an electric pump like that on my TR3 mounted inline for the last few years. Have not had any fuel delivery issue. It has help on hot start issues.
Don
Gliderman8
Gliderman8
That is good to know Don. One question: Is the pump noisy?
dklawson
I'll answer the "noisy Facet" question. Yes. However, if you put the pump on rubber mounts it is a lot better. Unlike an electric SU pump, a Facet runs all the time. You are not likely to notice either when you are at speed. You will notice a Facet pump at idle, particularly if it is on a panel that can vibrate on its own.
donbmw
I only hear low tic tic sound.
Don
DNK
Don- Any chance that's the valves?:excitement:
BobbyD
Before converting to TBI, I had the facet pump located in the trunk on the left side next to the tank. Facet is pretty specific about location relative to the tank outlet. These pumps do a good job at pushing fuel but not so good at pulling fuel. I isolated the pump with rubber between the pump and mounting point. They're not loud per se..... they click.
donbmw
I only hear this tic tic when the pump is on. I installed the pump more for hot start problems.
Don
Gliderman8
Gliderman8
I considered the area on the left in the trunk.... but, how did you manage to plumb the "in" line from the tank. As you know there is a hole in the trunk directly under the outlet fitting of the tank that is only accessible from underneath the car. Did you have it hooked up with the stock tank?
Any photos or further advice as to routing the feed line would be appreciated... thanks!
hondo402000
I put my carter pump in the boot, place where described above, thing is you can mount it in the engine bay as long as its at the same level at the mechanical pump, even though its a pusher, it is lower than the tank so it will have a natural flow to it.
Gliderman8
Gliderman8
hondo- You are correct... the instructions with the pump just say to mount with 12" VERTICAL of the bottom of the fuel tank. Anywhere on the frame (longitudinal) falls within those parameters.
So how did you access the outlet of your tank when you installed your carter pump in the trunk?
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Gliderman8 TR6 Inertia switch mounting location Triumph 4
P TR4/4A Body mounting plate location? Triumph 2
memphis License Plate [rear] Mounting Location? Austin Healey 12
C Mounting hole location for rear chrome bumper Spridgets 2
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
