100-6 Exhaust Front Mounting Bracket
Kirby
Would someone please share a photo or diagram of the correct mounting location for the front exhaust mounting bracket (the one that is bolted to the front of the muffler). I purchased a new chassis from Killmartin and it does not have any mounting holes in the chassis for this hanger. I bought a new hanger bracket from Moss. It appears that my two choices are to rotate the hanger so that it faces forward, and I drill into the underside of the frame outrigger where it is cut out for the exhaust pipes, or I rotate it rearward and mount the hanger through the floor. Mounting it through the floor puts the muffler less than an inch from the underside of the floor (not desirable at all in terms of heat transfer). The Moss catalog shows the hanger attached with two screws to the chassis, no nuts. Thanks, Kirby
red57
The front mount has bolts and nuts through the floor - if you went into the outrigger you would have to rely on threads in a very thin piece of steel.
You do want the muffler as high as possible for ground clearance reasons, on mine the muffler is close to touching the heat shield.
As to location, I never found any published info, I checked several cars when restoring mine and found the mounts in the same general location, but not exactly the same - I suggest waiting until you have the engine & exhaust system installed and you are happy with the location of the muffler and tailpipes and then the drill holes for the mount. BTW, I also suggest using elevator bolts inserted from the top (with seam sealer under the heads) and nuts below the hanger because their large diameter heads spread the load and their very low profile makes less bump in the carpet.
K
Kirby
Good to know! Thank you. If it was recommended to bolt through the floor, I was leaning towards that type of bolt head. Also thought of installing a small metal plate above and below the floor to help spread the load. My engine and exhaust are already installed in the car, so I am well on my way. Also, mine is a BN4, so there is not a factory heat shield, but I am going to try to construct one. Thank you again, Kirby
K Wanted 100-6 exhaust manifold for two port head Austin Healey Classifieds 0
C Correct mounting of exhaust on my 100-6? Austin Healey 9
bighealeysource Derrington style exhaust headers on 100-4's Austin Healey 4
S 100-4 exhaust Austin Healey 3
B Dual exhaust for 100-4 Austin Healey 0
mbrooks 100 Exhaust - torque settings, gasket sealant?? Austin Healey 3
mbrooks 100 exhaust Austin Healey 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
