mbrooks
I just discovered that my exhaust manifold was loose on the head. On investigation I discovered two studs with stripped threads - PO had tried to get a seal by using washers under the nuts, and in some cases by using steel nuts instead of the correct brass ones.
I now have the manifolds off, and have managed to get all the old studs out by locking two nuts together on the studs [in one case the threads were so bad I had to force a wrong threaded nut on to get the grip needed].
Questions:
1] The manual doesn't seem to have torque settings for the studs into the head, nor the manifolds to the studs - any experience??
2] What if anything are people using for gasket sealant??
3] Are there any differences in the gaskets or studs supplied by the usual suspects?
4] Any other words of wisdom on the job of reinstalling the exhaust and inlet manifolds??
Thanks as always
Questions:
Thanks as always
