TR6 Mounting location for electric fuel pump on TR6
DNK
Isn't there a hole there already.
Can't remember.
If not I drilled a new one when the carter was planed for my build.
Anyone want to buy a Carter?
Gliderman8
Gliderman8
Don- The outlet is on the left side of the tank; the outlet sits over a hole in the trunk and there is a short metal tube coming out of the bottom of the tank which connects to the tubing running along the side of the frame.
How then do you bring the exit point of the tank back into the trunk to connect to the pump? Anybody?
DNK
Been looking for my old pics
I'll see if I have any
Gliderman8
Gliderman8
thanks
DNK
No luck
I think I lost a USB drive on the trip over with those pics
IF there is no hole
The PI models got there somehow.
drill 2 more
Gliderman8
Gliderman8
I'm not concerned with mounting the pump or even running the outlet from the pump to the carbs.... my major concern is making the connection from the tank to the inlet of the pump since the connection to the tank is only accessible from under the car.
What I'm trying to say is that if I mount the pump in the trunk, I would have to run a fuel line from under the car where the tank fitting is back to the pump which would be in the trunk.
I will have another look to see if I missed something.
donbmw
I did not run a new line from the tank to the electric pump. It is using the original fuel line. I mount my pump to the LH side of the spare tire tub. Cut fuel line and used hoses from line from tank to electric pump. Hose from electric pump the fuel line to engine driven pump.
Don
Gliderman8
Gliderman8
Thanks don for the explanation Don... one question: Was this on your TR3A or a TR6?
Gliderman8
Gliderman8
The line from the tank on the TR6 is accessible from underneath the trunk, there is no connection to "cut" inside the trunk to make the hookup to the pump.
Gliderman8
Gliderman8
The RED ARROW is pointing to the tank outlet which goes through a hole in the trunk and is only accessible from below the trunk.
donbmw
On the TR3 the line from the tanks is the same. You can only get to it form under the car. I found place that was clear of anything and as close to the tank.
Gliderman8
Gliderman8
Don- Maybe I interpreted your mounting instructions for the pump incorrectly... are you saying you mounted the pump on the LH side of the spare tire well on the bottom of the car? That would make sense only I would have to remove the exhaust pipes to get to that area.
donbmw
Yes it is mounted on the out side of the tire well but on the side of the tire well. I wanted the pump as close as i could get it to the tank and it would clear anything that moved up and down or round and around.
Gliderman8
Gliderman8
OK, now that makes sense. I just hate the thought of removing the mufflers to get to the mounting location.
BobbyD
OK....I've got a whole new section on my site about upgrading to a custom aluminum tank.......but there's also some pictures on the stock holes in the floor of the tank area.
Ignore hole # 3....... I drilled that one but all the others are in every TR6 tanks floor area and, I think, in every TR4 too. So mount the pump next to the tank and run the lines up and down through those holes.
EDIT.......... I found some pictures on a back up DVD that showed how I did the Facet pump. It was actually mounted behind the trunk panel but attached to the side of the spare tire well. What I don't remember is if that hole in the spare tire well was there or if I drilled it. So the fuel line came out of the tank bottom (stock location) and up through hole #2 to the top of the Facet pump. Then out the bottom of the pump, through the spare tire well floor where it reconnected to the steel fuel line to the front of the car. You can also see how I mounted it with rubber and wood to minimize the clicking sound
DNK
See Elliot. Told you there were plenty of extra holes there
Gliderman8
Gliderman8
Just returned from Richmond, so sorry for the late reply. Yes, I always knew there were plenty of holes with plugs back in that area; it was the routing of the "fuel in" and "fuel out" that I had questions about.
DNK
Doesn't really matter what holes you use
Use 1 for in and another for out
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Gliderman8 TR6 Inertia switch mounting location Triumph 4
P TR4/4A Body mounting plate location? Triumph 2
memphis License Plate [rear] Mounting Location? Austin Healey 12
C Mounting hole location for rear chrome bumper Spridgets 2
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
