TR2/3/3A Mounting a stock steering wheel.
sp53
Mounting a stock steering wheel. I guess the wheel tightens down on the taper of the shaft with the tapper of the wheel and then torques down to a set number. My concern is I modified this car for a split column and it seems to me the wheel could hit the outer ring of the outer column before the tapper is tight. I guess the outer column should push down with the inside clamp loose inside the car.-- But anyways, does someone know the torque of the nut for the wheel?
steve
TR3driver
Great Pumpkin - R.I.P
Right, the outer column should be positioned so it doesn't hit the wheel.
The only spec I've found for that nut is in the TR6 manual (and of course the TR6 isn't the same). 34 ftlb.
But I believe it is important not to put too much force on the steering box. So I hold the steering wheel with the other hand, and tighten the nut as much as I comfortably can with one hand on an ordinary 1/2" ratchet. I'm guessing that might be around 30-40 ftlb.
S
sp53
Yes I was kinda where you are at Randall, I did want to pull the shaft too much and I wanted the tapper to be snug. The nut has some punches 3 on it to act kinda like a nylocks nut and IIRC the last nut I put on had those punches on it also. Have you seen that before?
TR3driver
Yes, I've seen those dimples as well; and my nut does not turn freely on the shaft. I've never had a problem with it coming loose, but a few drops of green Loctite certainly wouldn't hurt, if you want to make sure.
CraigLandrum TR2/3/3A Stock TR3 Fan mounting Triumph 9
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
G TR4/4A Silly Distributor Mounting Question Triumph 9
J Mounting 3000 engine to stand Austin Healey 7
