box spridget grill mounting tabs / ears / brackets
Branson
I purchased a wire mesh grill for my '65 sprite awhile back and didn't realize that it didn't come with the mounting ears that are riveted to grill. Anyone know where I can purchase those tabs or should I just buy another grill and remove the tabs from it?
Thanks!
nomad
Make your own. 2 on the bottom....4 on the top. I slot the bottom ones so that they will slide on to the bottom bolts and use speed nuts on the top. Fitting the grill can be a PITA.
Kurt.
Branson
Branson
Thanks guys. I made some crude ones out of some thing gauge steel that I had lying around. Was just looking for something a bit more refined.
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
Branson later spridget pedal box install in early spridget Spridgets 21
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T 1971 Fuse Box and Wiring Triumph 7
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
N TR5/TR250 Starter Box Assembly Leak Triumph 14
W General Tech 2500S starter motor and fuse box questions Triumph 3
Popeye General TR Old robbins top in box Triumph 7
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
R TR6 Heater box Triumph 6
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Martinld123 Steering Box Leak Austin Healey 27
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
F TR4/4A Locked out of glove box Triumph 1
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
A MGB MGB a glove box door MG 10
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
AngliaGT MGB-GT How Do I get the Glove Box Opened? MG 16
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
D Socket for TR3 Gear box drain plug Restoration & Tools 6
M TR6 Fuse box wiring mystery Triumph 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
D TR2/3/3A Battery Box drain Triumph 9
Basil Now THIS is a tool box Restoration & Tools 6
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
Walter74 Steering Box End Play Austin Healey 2
G Glove Box Lock Austin Healey 2
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
M TR6 Glove box lock. Triumph 4
Healey Nut Heater Box Installation Austin Healey 4
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
