TR6 Heater box
Ribbs
Hoping for some guidance here. I removed the heater box because the fan was no longer running and will take the opportunity to replace the heater core while it's out. I put the assembly on the bench and applied power to the leads but as expected, the motor still wasn't running. I can see that the fan spins freely however (but assuming the motor is still shot). Short of a gently used motor, are there still sources for new ones? Of course, I'm nervous about a scenario where I need to remove the fan too.
NutmegCT
Until the Knowledgeable Ones add their suggestions, you might take the unit to a local electric motor rebuilding shop. They do starters, generators, alternators, electric motors of all sizes - usually by replacing the internal windings. One possibility:
Rimmer had one, but they may have some suggestions if you contact them.
R
Ribbs
Thanks Nutmeg. By coincidence, I'm just outside of Dayton, OH! I will try Rimmer Bros. first. Maybe they'll have a fan wheel too - assuming I won't get that off the old motor...
malbaby
Have you considered fitting a modern replacement fan. The mounting holes will not be the same, but is very doable.
malbaby
I used a Spal 5 1/4" fan that I had, but had to make a back plate for it as it was a little small in diameter. I think 5 1/2" is a better fit.....[the Spal bolt patterns do not match anyway]
Suggest you search other sites for confirmation of the ideal size.
R
Ribbs
Well, I lucked out. Once I opened the heater box, I could see that my problem was that the earth ground wire spade connector had been pulled off of the motor body. Whew! I think I'll buy a lottery ticket today :smile:
If anyone's curious, the motor draws approximately 2 amps at low speed and 3 amps at high speed.
Healey Nut Heater Box Installation Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
R Heater box assembly assistance Austin Healey 16
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
C Help me identify this Heater Box, Please Austin Healey 7
Rut TR4/4A Heater box Triumph 1
C Value of 100-4 heater box?? Austin Healey 2
Boggsy64 MGB Heater / Air box drain MG 21
Lynn Kirkpatrick MGB Heater Box Removal MG 8
B Up-date on heater box refurbishment Austin Healey 0
B antifreeze ccming out heater box feed? Spridgets 4
D Smith's Heater Box - AH Spares Spridgets 9
I TR6 Si sealant for TR6 heater box? Triumph 1
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
69MGC MGB MGB Heater Box Removal MG 15
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
jvandyke heater box plates Spridgets 3
Lin Cape international heater to replace Smith's Box Austin Healey 7
N Heater box removal MG 9
Steve1970 Getting the heater unit box out Triumph 16
I BE heater box questions Spridgets 7
S Heater Box Extracted! Spridgets 13
Mg_Bizzle Heater box MG 29
H Would anyone like a heater box? Spridgets 0
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
AUSMHLY Water is leaking into - out of heater box Austin Healey 13
Baz Heater box / cooling system Spridgets 8
TR674 Heater box painting Triumph 16
KLUTZ Opening the front of the heater box Q. MG 18
vping Heater box MG 19
R heater box drain tube MG 3
jlaird Another darn heater box question Spridgets 6
John Loftus heater box mystery studs Austin Healey 31
A BJ8 Heater Box - Suggestions Austin Healey 2
Bill Redd Heater box fan Triumph 4
Bill Redd Heater Box Rebuild Triumph 10
CDK Heater box Grommets [Parts Find] Austin Healey 7
M TR6 TR6 heater box arm Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
I MGB 1980 mgb heater box MG 2
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
