TR6 Heater core
Buckshot57
71 TR6 heater core. Appears to be in good condition. I ordered a new one before disassembling the heater or I would have reused it.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
C Testing heater core Austin Healey 9
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
R TR2/3/3A Heater Core Triumph 2
R Radiator Heater Core Austin Healey 12
S TR2/3/3A heater core Triumph 4
Jake Healey 100 heater core size? Austin Healey 1
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
AngliaGT Heater/Heater Core..........Durrrr! Spridgets 8
Got_All_4 Wedge Heater core leak. What am i in for? Triumph 3
B TR6 TR6 Heater core plugged? Triumph 9
Pythias Heater Core Replacement Spridgets 7
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
George Zeck Heater Core & Battery ...... Spridgets 5
Luke_Healey Cheap options for a heater core? Spridgets 11
mgbmedic Wedge 1980 TR7 Heater Core Triumph 2
N MGB What came out as I pulled the heater core for MGB MG 7
L Heater Core Testing Spridgets 4
OregonTR4A TR4/4A Help with Heater core in a TR4A Triumph 3
rlandrum Heater Core Motor Triumph 10
N Heater core Question Triumph 10
B Midget 1500 Heater core flow Spridgets 3
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Brosky TR6 TR6 Heater Case/Core/Motor Repair 101 Triumph 4
O TR6 Pressure testing a TR6 Heater core Triumph 16
msoylemez heater core to valve on block not aligned Spridgets 12
AUSMHLY Water Leaking - Heater core and core plug Austin Healey 7
S Wedge TR7 Heater Core Triumph 1
bmurphy7369 Audi 100... Heater Core Monstrosity! Other Cars 5
EMGEBE Heater Core MG 26
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
