The PO of my 72 TR6 had removed the valve and plugged the threaded hole where the valve attaches and the lower heater hose. As the weather is getting cooler I decided to take a crack at it and see if it was just the valve. Put a new valve in, and tried it. Hot upper hose, lower hose not heating up much at all, no heat in car. Removed lower hose again from valve, no water coming out (engine stopped of course). Assume my heater core is plugged. Life is busy now, not sure I want to take it out of the car. Have seen various suggestions to backflush, as long as you watch the pressure. Before I just jump in and do this, what have you all discovered with unplugging heater cores?
