TR6 TR6 Heater core plugged?
Bruce100
The PO of my 72 TR6 had removed the valve and plugged the threaded hole where the valve attaches and the lower heater hose. As the weather is getting cooler I decided to take a crack at it and see if it was just the valve. Put a new valve in, and tried it. Hot upper hose, lower hose not heating up much at all, no heat in car. Removed lower hose again from valve, no water coming out (engine stopped of course). Assume my heater core is plugged. Life is busy now, not sure I want to take it out of the car. Have seen various suggestions to backflush, as long as you watch the pressure. Before I just jump in and do this, what have you all discovered with unplugging heater cores?
Gliderman8
Not so sure there's much you can do except to flush it out with a garden hose in EACH direction. I got some brass garden hose fittings and just hooked up the hose, turned on the water and let it run for 20 mins or so. Then reverse the hose's and do it again.
It is a real PITA if you have to remove the heater core. Hopefully flushing it will do the trick.
Gliderman8
Honestly, I didn't... Maybe you should wait until others give you their thoughts regarding pressure.
mrv8q
Flushed both my 3 and 6 heater cores with hose pressure. Radiator shop wouldn't touch either core. Not that they're all that hot, but no problems.
trrdster2000
Bruce100, If you have to replace it, I have a couple and will check them out for you. I'm just up the road in Salisbury, give me a PM if I can help.
Wayne
Deleted member 8987
I have used a standard garden hose with trigger spray nozzle for......50 years? on all types of heater cores, never, as in ever, had any type of overpressure issues. Of course, I did not make a hard connection, rather just held the nozzle up, pulled the trigger, same on other side, back and forth until clear.
Did you say the core pipes were plugged? Gave you probed to the end of the pipes (without hitting the tubes) to make sure some plug isn't in there?
Dave
glemon
I had the same problem on my 4a many years ago, I blew it out with some reverse pressure compressed air. Didn't need to take it out think I put a large cup and some towels in there. Wad of rust colored goop came out worked fine after.
Brosky
Just be careful. I have very high water pressure at my house and these units were only designed to work with a 16 lb max pressure in the system. And that was when they were new, not 40 plus years old. You don't want to accidentally split any seams.
And if you want to know what they really look like, you can see one here: https://www.74tr6.com/heater.htm
Brosky TR6 TR6 Heater Case/Core/Motor Repair 101 Triumph 4
O TR6 Pressure testing a TR6 Heater core Triumph 16
R TR6 Heater control bezels TR6 Triumph 2
TR3TR6 TR6 Triumph tr6 heater motor Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
D TR6 76 TR6 Heater/Blower Switch Triumph 1
W TR6 installing heater hoses '74 tr6 Triumph 1
I TR6 Si sealant for TR6 heater box? Triumph 1
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
I TR6 TR6 heater removal help please. Triumph 5
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
I TR6 Help with rebuilding TR6 heater system please Triumph 19
I TR6 TR6 heater fire Triumph 15
bigbadbluetr6 TR6 TR6 Heater Triumph 14
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
J TR6 Tr6 heater assemblies Triumph 8
bcbennett TR6 TR6 Heater Fan question Triumph 9
WidespreadPanic TR6 Disable Heater on a TR6? Good idea? Triumph 10
I TR6 TR6 heater suggestions Triumph 8
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
T TR6 tr6 heater motor wanted Triumph 13
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 TR6 heater hoses. Triumph 1
I TR6 69 TR6 heater control cable Triumph 6
V TR6 TR6 Radiator and Heater hoses Triumph 8
RomanH TR6 TR6 Heater function Triumph 12
Brosky TR6 TR6 heater fan switch replacement Triumph 7
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Webb Sledge TR6 TR6 Heater switch Triumph 2
G TR6 Removing heater from my TR6...... Triumph 14
H TR6 tr6 heater motor resistor Triumph 0
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
M TR6 TR6 heater box arm Triumph 4
A TR6 TR6 Heater Control Question Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
P TR6 72 tr6 heater blower Triumph 2
S TR6 replacement switch for TR6 heater fan Triumph 5
A TR6 TR6 Heater Problems Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
