TR6 Heater Control Plinth Light for 73 TR6
jerrybny
Hi, if anyone runs across the light and conector for a 73 TR6 heater Control plinth please let me know. Seems the PO cut it off. Go figure. I'm been searching the web and ebay but only found one for a 74 TR6 which is different than the 73. Thanks
Yellowdog
Jerry,
The only lamp listed for this application in the old green TRF catalog is for the 73 - 76 cars after commission number CF1. Their part numbers are 219139 for the lamp and LULL8286 for the bulb. I did not check availability.
I think this change coincided with the moving of the ignition key from the heater switch plinth to the steering column, but would not bet the farm on it. . . .
Steve1970 how does the heater control plinth connect? Triumph 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
B TR6 Removing the ckoke/heater control knobs Triumph 4
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
W Heater Control Tap Spridgets 3
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
58Custom Heater control valve. Suggestions? Spridgets 39
H Heater control question MG 3
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
Stewart heater control cable lenth? MG 0
S removing knobs from heater control etc Triumph 4
2wrench Heater control valve and spigot install Triumph 20
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
Dave Richards Stuck heater control lever Austin Healey 4
VelodromeRacer Leaking Heater control valve Austin Healey 5
I TR6 69 TR6 heater control cable Triumph 6
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Musicman Installing Heater Control Cable Triumph 3
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
