TR4/4A TR4A Heater Control Valve Help
Stinger
I was replacing the heater hoses on my TR4A and the outlet pipe from the heater control valve was so corroded that there wasnt enough pipe left for the hose clamp. So when I tried to unscrew the control valve it broke. Ive tried heat,easy out,cutting the broken piece with a hacksaw blade and it wont budge. Its like its corroded to the adapter pipe. My question is how is the best way to remove the adapter pipe from the head without any further damage and also if I do get it loose will it come out without hitting the head stud? Thanks
TR4nut
I broke one off as well - if you are careful, you can take a drill to the inside of the pipe and remove as much metal as you can - it is very soft alloy. Then chase everything with a pipe tap and you'll be good to go. I would not try to remove the angle adaptor unless you had too - I've broken one off before and that is worse. It will interfere with the head stud.
Stinger
Stinger
Thanks for the fast reply! How did you keep the drilled out particles from getting into the coolant? Would a small amount in the coolant hurt anything? What size pipe tap did you use? Also who sells the best quality control valve or are they all the same? Thanks again.
PeterK
When I drill out a pipe, I used a step drill. It cleans out the edges really well.
TR4nut
I'm betting there are better ways, but other than grabbing as much debris as I could I didn't worry about the particles that fell in. Probably running a shop vac at the same time would help, or you could very carefully stuff some fabric or other plug into the hole, but there would be the risk of it getting into the engine. In my case, I knew I had a lot of built up material in the engine already so I didn't think a little more would hurt it. And so far, it hasn't!
I haven't heard of any differences in these valves, Moss or TRF would probably be my first stop.
Stinger
Stinger
I just remembered I have a set of the step drill bits so I will try those and order a new HC valve. Do you remember which size pipe tap you used?
TR4nut
Sorry, don't recall exactly, but as a guess I'd say 1/4 npt.
trfourtune
Drill and tap is probably your only option, but, the metal shavings will end up in your rad, plugging some of the cooling. They could also cause problems with your thermostat. You might want to drain your cooling system and remove the thermostat, housing, water pump, and hoses. then flush the block every which way you can. You probably need to do this anyways.
Rob
Stinger
Stinger
I finally removed the broken piece of the heater control valve and Im pretty sure I dont want to do this again! Question. Will a SAE tap clean the pipe threads up or should I go buy a NPT tap? Thanks
PeterK
You need a pipe thread tap, the threads are tapered. Yours doesn't look too bad though and you might get by with some teflon plumbers paste (or tape).
Stinger
Stinger
Just received a new heater control valve and I have a question. The new one seems to stop and catch with a clicking sound kind of like its in a bind. Is it suppose to be this way or should it operate smoothly? I just dont see how the cable will be strong enough to open it. Thanks
J TR4/4A TR4A Heater Control Valve Question Triumph 4
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
M TR4/4A TR4A heater hoses Triumph 3
H TR4/4A TR4A heater mounting Triumph 2
OregonTR4A TR4/4A Help with Heater core in a TR4A Triumph 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
