Stinger
I was replacing the heater hoses on my TR4A and the outlet pipe from the heater control valve was so corroded that there wasnt enough pipe left for the hose clamp. So when I tried to unscrew the control valve it broke. Ive tried heat,easy out,cutting the broken piece with a hacksaw blade and it wont budge. Its like its corroded to the adapter pipe. My question is how is the best way to remove the adapter pipe from the head without any further damage and also if I do get it loose will it come out without hitting the head stud? Thanks
