Heater Control Panel
Rob Glasgow
I recently purchased a new heater control panel for my BT7 from Moss. When I tried to install it I noticed it had a dip in the top edge where the panel meets the dash, instead of being flat like the original panel. This left a small gap between the dash and the top of the panel. Moss sent another but it had the same concave top surface as the first.
I called Moss and had them check several other panels and all of them had the dip.
My orginal fits the dash perfectly with no gap. Anyone else run into this problem? Is there another source that fits better?
CDK
Rob.
I just got around to installing a panel that I have had for a couple of years and I also have a small gap. The old one has been out for so long I can not remember how it fit. I did not see any paticular way to get rid of the gap but it is uniform on mine so it looks correct.
CDK
H heater control panel and knobs Austin Healey 1
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
B TR6 Removing the ckoke/heater control knobs Triumph 4
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
S Choke & Heater Control Knobs Triumph 2
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
W Heater Control Tap Spridgets 3
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
Steve1970 how does the heater control plinth connect? Triumph 4
58Custom Heater control valve. Suggestions? Spridgets 39
H Heater control question MG 3
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
Stewart heater control cable lenth? MG 0
S removing knobs from heater control etc Triumph 4
2wrench Heater control valve and spigot install Triumph 20
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
Dave Richards Stuck heater control lever Austin Healey 4
VelodromeRacer Leaking Heater control valve Austin Healey 5
I TR6 69 TR6 heater control cable Triumph 6
Musicman Installing Heater Control Cable Triumph 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
A TR6 TR6 Heater Control Question Triumph 4
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
