Heater Control Cable
jhorton3
Can you use a control cable from a bicycle shop on the round knob heater controls? If so what length should I be looking for?
Platinum
If you can find a solid wire one with the right spiral OD sheath to fit the clamping device it may work. Bike cables are multi-strand and don't work well when "pushed" though. All are for tension IIRC. Think Granger, lawnmower controls. Solid wire.
jlaird
Your favorate auto store should have the solid cables, known as Choke cables in the trade, come in about 6 foot lengths.
Just the thing to replace the heater switch cable.
KVH General Tech Heater control valve/cable Triumph 1
Stewart heater control cable lenth? MG 0
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
I TR6 69 TR6 heater control cable Triumph 6
Musicman Installing Heater Control Cable Triumph 3
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
B TR6 Removing the ckoke/heater control knobs Triumph 4
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
W Heater Control Tap Spridgets 3
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
Steve1970 how does the heater control plinth connect? Triumph 4
58Custom Heater control valve. Suggestions? Spridgets 39
H Heater control question MG 3
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
S removing knobs from heater control etc Triumph 4
2wrench Heater control valve and spigot install Triumph 20
Dave Richards Stuck heater control lever Austin Healey 4
VelodromeRacer Leaking Heater control valve Austin Healey 5
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
