Steve1970
Hi all,
I was replacing the radio in the tr6 over the weekend and notice two wires (red and black) coming from the bulb socket of the heater control plinth (see part #73). This is the thin plastic strip located below the heat/choke knobs and above the radio.
What switch should I connect the wires to? Should I wire it to the dashboard display light switch? Or the map light switch (the pull knob below the radio)?
And what is the behavior of the light? does it light the entire plinth?
thanks!
-Steve
thanks!
-Steve
