TR4/4A Does a bolt legend exist?
Dash
Many years ago I had actually started a body off restoration of my 63 TR4 but got sidetracked and have been shuffling parts from here to there ever since to basically get them out of the way. I have all the original nuts and bolts bolts that are still good so getting replacements doesn't seem logical. Over the years,however, they have all gotten jumbled up and a lot of tags missing. Now that I'm able to finally continue the restoration process I find myself rummaging through a boat load of nuts and bolts measuring and testing.. Some are obvious, some not so much..Does a bolt legend exist for these cars or is that ridiculous wishful thinking? Sure would save a lot of time if it did..
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
T TR2/3/3A Does your rotor wiggle Triumph 15
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
B Does a 100 Six with no heater have demister vents? Austin Healey 5
