TR2/3/3A Does this fitting need a Whitworth wrench?
karls59tr
Bronze
The fitting is for the copper vacuum tube at the bottom of the front SU. carb,,, 5/16th dosn't fit. I've heard that the TR3 has a few nuts and bolts that are Whitworth and I was wondering if this was one of them?
PAUL161
Probably leftover parts in the nut & bolt bin? :unsure:
JHaydon
I just went out and tested mine, a 1/8 W - 3/16BSF wrench is correct.
According to my crossover lists, 1/8 W measures 0.340" across the flats and 9mm measures 0.354" so a 9mm could maybe work in a pinch, as long as the nut isn't too tight. A 9mm wrench will be a looser fit than, say, an 8mm wrench on a 5/16" hex 0.014" larger vs 0.0025" larger). On top of that, wrenches are typically a hair oversized (which is why a 19mm socket fits 3/4" lug nuts, despite 19mm being 0.002" smaller than 3/4").
If this is your first time removing that nut, I'd be very concerned about rounding off the hex with a 9mm wrench.
K
karls59tr
Bronze
I carefully used needle nose pliers and I had the carb removed enough to turn it upside down for easier access.(y)
mctriumph
My Morgan had whitworth , Most of which are now in the re-cycle bin. Hate them. Nothing
will rust as solidly as a whitworth(more surface area on each thread) /
Mad dog
JHaydon
Don't know whitworth much. Thought it was a function of threads
Whitworth does indeed refer to the thread size, but in the Whitworth system the hex head size is consistently matched to the thread size. This is partially so that the wrench you use will be the appropriate size (length) to apply "correct" torque for the thread size.
In SAE and metric, there's no standard hex size for a given thread size. You may encounter a bolt with one hex size and a matching nut with a different hex size.
So, instead of calling out the hex size (as SAE and metric systems do), Whitworth wrenches call out the thread size.
Conversion charts as on this page are extremely helpful, I keep laminated copies in each car and in each toolbox:
> Convert,compare all Imperial tool,nut,bolt and spanner sizes to metric. <
And amplifying on MD's reply, Whitworth threads are easily confused with SAE UNC (coarse) threads because the diameters and (most) pitches are the same. The problems are in the thread angle (55 degrees vs 60 degrees) and the thread root (generous radius vs squared-off). You can thread an SAE nut onto a Whitworth bolt and vice-versa, but it will take effort and will usually ruin both pieces of hardware.
Platinum
And: "Cross-threading is Nature's LocTite!" :devilish:
L What does this column switch do? Spridgets 4
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
T TR2/3/3A Does your rotor wiggle Triumph 15
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
B Does a 100 Six with no heater have demister vents? Austin Healey 5
