TR4/4A Shortening the Steel Wrapped Heater Control Cables
KVH
Dare I shorten these, or will cutting cause them to flip out of control? My heater line is just crammed in so tight, I'd like to use a bolt cutter to take off 1/2 inch. Dare I?
KVH
KVH
Pull the cable out first, then cut off the outer shield. I have done that on a few.
Jerry
Thanks, that was easy. I wondered all along why the factory would create that bird's next back there, but maybe they didn't. The short length cleans it up, and the longer length may have been an after-market install. I haven't checked what the new cables look like, but I hope they're decent reproductions.
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
JimTR4 TR4/4A Shortening the gear stick Triumph 2
regularman Shortening the list of things yet to be done. Spridgets 14
vping MGB Shortening a MGB shift lever MG 51
G TR6 Shortening TR6 Stroke..... Triumph 9
G Shortening my Chrome-Moly push rods Triumph 12
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
T Trying to identify a steel plate part Austin Healey 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
K TR2/3/3A Pressed steel body plates?????? Triumph 7
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
busybrit TR4/4A Steel dashboard color Triumph 1
JimLaney How to treat media blasted steel Spridgets 3
B ISO two[2] steel road wheels, Morgan Other British Cars 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
T TR2/3/3A TR3 steel wheels Triumph 6
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
simon1966 The jigsaw puzzle in Aluminium and Steel Commences. Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
D TR2/3/3A Tubes in steel wheels? Triumph 15
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J TR2/3/3A TR-3 Steel Wheel Repair Triumph 3
M Front steel brake lines Spridgets 9
BillyB62 TR2/3/3A Factory steel hardtop Triumph 14
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
J General Tech Stainless-steel caliper pistons Triumph 8
