mightymidget
While I am having master cylinder redone need to prepare original brake lines.
1. Clean with reducer then rub down with scotch pad? Also run reducer down inside then blow out with air ?
2. The steel line from my slave cylinder goes about 2" from slave then has a union, is that stock ? Or did someone along way mangle original line then added a piece of steel line back
