dbenichou289
Member
So I have to hook up the heater motor now. While reviewing the service manuals I have, it shows the heater assembly as an option and only lists connections required. Sooooo, where and how do I hook this up? I have the heater knob mounted to the left of the steering wheel on the dash (I presume it is the heater knob as it is the last of the 'unmarked' knobs remaining with just 2 prongs on the rear).
Where do you all connect to find the power source? I presume it then goes through the knob, then to the heater. On a side note, the heater has 3 wires on it (one has a looped eyelet, the other 2 wires are open ended - so what goes where? A diagram would help tremendously.
And one more last stupid question....how does it work? Is the knob a rheostat where when you turn it on is comes on at a slow motor speed then speeds up as you turn the knob further? or something else?
