Luke_Healey
I've got a leak under pressure in the heater core in my '66 Sprite. I plan on removing it from the car and figuring out where the leak is to see if I can solder it.
Do any of you know off the top of your head if there are some generic heater cores you can plumb into the metal box and just surround with insulation or something? Some 20 dollar unit for a common car like a '79 Chevy or whatever?
I can run rubber hose to the outlets on the metal box from the inlet and outlet of said cheap heater core. I just want something cheap I can pick up at the local parts store. I might run in just to see if they have anything anyway.
I was just curious since I don't feel like paying 90 dollars for a replacement and I rarely use heat other than right now when it's 30 degrees F in the morning on my way to work.
Thanks for any leads!
