Wedge 1980 TR7 Heater Core
mgbmedic
Has anyone replaced/repaired heater core on a TR7. It takes a lot of patience and someone to translate english into american, i.e. draught excluder? I'm using a Haynes manual to get to it. Looking at VB replacement, it doesn;t have the long pipes to the firewall. Looks like a modification is needed. I'm also installing a tranny and twin webers. Any helps appreciated. bob
Mickey Richaud
Not a fun job, but one of those "I DID IT! experiences.
I believe the draught excluder is the little flap door behind your center dash vents.
Also, the A/C model heaters are not the same as non A/C. Maybe that's the difference...
Mickey
WedgeWorks
I have replaced the heater assemblies numerous times. They are not that hard to do. Pull the center council and the dash. Then from there disconnect the wires towards the back/top for the blower motor. Then drain the coolant fluid. Disconnect the AC supply & return lines. The heater assembly is held in by bolts on the transmission tunnel and brackets and dont forget the two nuts on the fire/bulkhead wall just above the transmisison tunnel. One holds the gas tank vent pipe and the other is below the coolant pipes. Then give it a yank, no tools and the seals should work free. At this point replace all of the seals and padding. If you do not plan of keeping ths AC system, if the car has AC you might want to find a non-AC heater assembly that is much lighter than the AC model or removal all the AC guts from the AC heater. If you change from AC to non-AC the molded vents for the windshiled defrosters are different between AC and Non-AC.
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
A Wedge 1980 TR7 Brake master Question Triumph 5
Got_All_4 Wedge Drove a 1980 TR7 today PICs Triumph 16
Got_All_4 Wedge Going to look at a 1980 TR7 on Thursday Triumph 43
G Wedge Need help with 1980 TR7 Triumph 2
bmurphy7369 Wedge TR7 DHC fans, advice on value/feasability of 1980? Triumph 7
M Wedge New Owner of 1980 TR7 Convertible Triumph 8
D Wedge 1980 TR7 Convertible value Triumph 3
F Wedge Background on my 1980 TR7 & current Idle problem Triumph 3
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
S Wedge Potential Buy: Pros v. Cons of 1980 TR7 injected? Triumph 7
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
A MGB 1980 MGB MG 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB 1980 Starter Relay & running problems MG 14
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
N "Ole 19" Freddy Baker 1980 win article?? Jaguar 1
1 1980 Panther Lima restoration project Other British Cars 11
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
AngliaGT .1980 Honda Accord Spotted 4
