1980 Panther Lima restoration project
19pantherlima80
Hello Everyone,
My name is Alfonso from Houston Tx and i am currently restoring a 1980 Panther Lima, based on the 2.3L, 4spd, Vauxhall Viva/Magnum floorpan and drive train.
So i wanted to start a project thread so that i can document my progress and get any help or tips i can get from you guys as i work along.
I have a Youtube channel (19charger74) where i have been making videos of the progress.
https://www.youtube.com/user/19charger74/videos?view=0
I hope to be posting more videos soon so stay tuned and follow me on my journey.
here is the latest video i did where i have already removed the body from the car and im now starting to dissassemble the front suspension.
https://www.youtube.com/watch?v=ShQ7MpXtkV8
drooartz
That's a very neat car you're working on. An interesting mix of parts as well. Good luck, and we'll help any way we can.
JPSmit
Alfonso, hi welcome! I think we have chatted briefly on the Vauxhall Viva boards as well. I am in Toronto and have the only Viva GT on the forum and one of 2 (that I know of) in Canada. To my knowledge they never brought the GT into the USA so you are looking for unbelievably rare parts! If you rummage around the Vauxhall boards a bit you might <might> find some alternatives. I seem to recall that some are using a Volvo rear axle and I know some here are using RX7 rear ends for their cars. Good luck! and if I can help, PM me or post. I also have pretty much all the manuals so if you need me to scan anything I am happy to, though they aren't so hard too find on ebay either.
19pantherlima80
Thanks Drew i cant wait to drive this car. Yes it is one big mix of parts. i have good luck so far searching and happen to find compatible parts with British cars that were more readibly available here in the states.
19pantherlima80
Hi John i remember you from the Vauxhall forum. So i guess your car is even more rare than The Panther Lima here on this side of the pond and you must know how hard adn frustration it is to find parts here on this side.
This is some good info to know about the rear ends, i will have to look into it. I at one point thought of using a Mazda Miata rear end but maybe in the future. Well from what i have researched Jensen Healey, more readily available in the US, alos used Vauxhall drivetrain and that the rearend from the Jensen will work with slight modification of lengths of the driveshaft and upper control arms. So currently im trying to hunt one down here in Texas if possible.
and thank you for offering to scan the manuals. If i need some info off of them i will let you know
Thanks Alfonso
19pantherlima80
I wanted to post this information in case anyone is searching:
This information will pertain to Jensen Healey & Panther Lima owners both based off of some of the Vauxhall Viva/ Magnum drivetrain components, in this case the rearend / rearaxle. This information was provided by a fellow member over at the Vauxhall Viva forum after looking at my Youtube video of me comparing the two rearends.
https://www.youtube.com/watch?v=FekqkY7aGlA
To assist you have a
good look at your diff casting, if its a magnum axle the ratio will be
identified by a letter stamped on the pinion housing (hard to find but worth
spending time looking)
on the top for OHC engines, bottom for OHV
engine
A - 3.88:1
B - 4.125:1
D - 3.45:1
K - 3.727:1
None -
4.24:1
(some are not stamped and these are OHV axles )
Apart from
some slight differences in brakes and handbrake the axles are a straight swap
for each other, bar two items
1/. Prop length some axles have longer
pinions that others.
2/. The two inner trailing arms, on the OHC axles
these are shorter, due the higher position of the two rubber mounts on the diff
casting (its easy to shorten the longer ones but harder to lengthen shorter ones)
Easiest method I know is to look at the diff cover, the OHV ones are
dome shaped the OHC ones have a pressing to make room for the diff unit.
Looking at your video/images I can see the clean looking axle on the bench is
a OHC axle, and the rusty one is an OHV axle.
Sounds like using the Healy
one will work, other than the two issues mentioned above, but the performance
will fall right off due to ratio change, although its top speed and MPG will
improve. The 5-sp Jensen cars have a 3.45:1 ratio while the 4sp cars have a
3.73:1, the OHV engine vivas came with 4.24:1"
19pantherlima80
for you guys wondering what a Panther Lima is here is a pic of the one im restoring
and where im at now. i have removed the interior, body, and now im working on removing the engine/trans and subframe.
and one day we hope it will look like this..
JPSmit
Nice! but why would you want it to look like a yellow 2CV? :wink-new:
seriously one of the better shapes out there - especially the grille! BTW as I said earlier I do have a spare HB axle but I think it would be too light.
Sherlock
Here's a 1979 Panther Turbo Lima in southern Alberta, the one here is in beautiful condition!
All the best with your restoration, is that how you purchased the car? In that condition...
19pantherlima80
lol yeah i dont think the yellow would work unless it was the Turbo version. And thanks for the offer on the axle John i appreciate it, though you are a tad far from where i am but if all else fails i might need to go visit canada for vacation lol.
19pantherlima80
Sherlock, now That is one beautiful turbo version ... No the car wasnt anywhere near the condition the turbo is in the picture. The condition was pretty much what you see on the first pic. The paint was rough with cracks, bad repairs, cheap single stage paint, the floor pan needs to be replaced because it is rusted through in some spots, alot of rust repair for the frame. The car was neglected for many years ... but i hope to restore to at least what that turbo looks like.
19pantherlima80
so we continue with the disassembly of the Lima. I removed the exhaust system, the steering wheel and shafts. i power washed off all of the dirt, grease and grime off of the shafts and rack and pinion so that i can store them away. now all that is left is to remove 4 bolts to drop the subframe and the bolts on the transmission crossmember and we can get onto repairing the frame.
Here is the latest vid of the updates.
https://www.youtube.com/watch?v=ilQfC2R7Z-M
Alfonso
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
A MGB 1980 MGB MG 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M For Sale 1980 MGB for Sale MG Classifieds 2
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB 1980 Starter Relay & running problems MG 14
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
N "Ole 19" Freddy Baker 1980 win article?? Jaguar 1
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
AngliaGT .1980 Honda Accord Spotted 4
S Wedge 1980 TR8 BULB Triumph 3
L Advice for cleaning/painting 1980 rubber bumpers MG 8
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
AngliaGT 1980 Bonneville T140 British Motorbikes 9
A Wedge 1980 TR7 Brake master Question Triumph 5
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Got_All_4 Wedge Drove a 1980 TR7 today PICs Triumph 16
W Spitfire 1980 Spitfire Coil Spring Replacement Triumph 2
Got_All_4 Wedge Going to look at a 1980 TR7 on Thursday Triumph 43
Tinkerman MGB 1980 MGB wiring diagram help MG 6
W Spitfire ZS carb on 1980 Spitfire Triumph 11
Gafirema California Emissions + 1980 MKIV 1500 Triumph 251
