Advice for cleaning/painting 1980 rubber bumpers
last1
Hi All,
Looking for advice regarding cleaning and painting (or making black again) the rubber bumpers. Previous applications of some sort of detail work has deteriorated and I'd like to refresh the bumpers.
Suggestions appreciated as well as what worked for you.
Also, I have the front license bracket. To install with OEM mounting parts, do I need to remove the front bumper cover?
TIA
Scott_Hower
If all else fails, Charles Runyan mentioned in last week's TRF mailing that BMIHT just did a small production run of brand new urethane MGB bumpers, ~100 sets. They're obscenely expensive; something like $900/each. Sadly, Charles also mentioned the tooling is set to be scrapped. :frown:
L
last1
Thank you for the link to the club.
I was out to Ben's shop last week and to my dismay, found that he has closed it down. Is that because he closed the business?, or relocated it? I remember him talking of relocating to a new building.
Last One
(1980 MGB)
glemon
I cleaned mine (used to have an 80 MGB LE) up and sprayed with "black rubber bumper spray" from the local auto parts store, if they are weathered to the point where no amount of cleaning will bring them back to the black you want this works great, think it was Dupli-Color or VHT brand, really easy to do, I think it maybe took me half an hour or so even with masking off the body around the project.
Robby
Member
Last One
(1980 MGB)
Ben closed his shop and got a "real job" with Nissan in Decherd, TN (which is close to his home). He told me at the Eurobrit show that he may eventually open up a small shop and do some part time work at his home but will be a while before he does that.
Bob
B TR2/3/3A Advice needed - cleaning TR3 brake pipe union Triumph 11
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
