MGB 1980 MGB Timing Issue
kyreb1862
I have read that the 18v engines rarely jump timing but I think it may have happened to me. The car had been running, not great but running. I had noticed that the timing was erratiic. I would set the timing at 10 degress come back to it a few minutes later and it would be on 20 degrees or maybe even somewhere on the ATDC side. When I would line up the marker on the damper with the pointer it would always point to No# 1. Yesterday while the car was running it suddenly backfired and quit. I tried to start it and it would buck the starter like it was badly out of time. This morning I checked the timing by putting the engine on TDC. Now I understand why the engine was bucking the starter. The rotor now points at #3 plug on TDC. All the ignition components are new or rebuilt. The distributor has been rebuilt and converted to mechanical advance to work with a 45 DCOE. The plugs, plug wires, cap, rotor and coil have all been replaced along with the ignition module in the CEI box. Any informed guesses as to what might have happened, or what I can check, or is a partial tear down inevitable?
JPSmit
Not sure about the tdc but the timing drifting like that seems to me that the dizzy isn't tight enough.
kyreb1862
kyreb1862
Actually I was also concerned about the dizzy being loose so I had snugged it up and it didn't help any thing. The engine was rebuilt at 45K and has 60k on it now. I think the biggest problem is that it was stored for 15+ years previous to my buying it. The car was a one owner till I bought it.
Platinum
The timing chain in there would be making alarming noises if it were loose enough to "jump" teeth, IMO. But if you're confident the dizzy is properly installed, in good condition and engaged with the drive dog, the timing cover is the next place to go. Bit of a pain as you'll need to get the engine off the mounts by about six inches and well braced.
kyreb1862
kyreb1862
The distributor was rebuilt by Jeff Schlemmer so I am confident of its quality. The distributor is bolted down and engaged with the drive dog. Looks like the timing chain cover is the next place to go. I was thinking maybe the tensioner was gummed up from so many years of sitting. I am stumped.Wish me luck.
Platinum
Well, at least we're here. If th' tensioner is an issue the cover will have "whitness marks".
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
