MGB 1980 MGB LE or not??
mk2sprite
Is there a way to tell if a car was a LE from the factory by the serial number? It's a 1980 and fits inot that years numbers but is the only way to tell is by the LE options on it?
Thanks
Mike
tony barnhill
Great Pumpkin - R.I.P
Sure...look in Clausinger's "The Original MG" & he has the list of LE VIN's.
M
mk2sprite
Tony, That's the first place I looked and was sure it was in the chart of production numbers but that does not tell exactly what numbers were LE's. I just looked under the LE section of the book and in a small paragraph he gives the number range of the LE's, although still confuses me a bit. I know there were alot of 1980 models produced that were not LE's but will go by that number range stated. Thanks
tony barnhill
He give's the number range of LE VIN's in that paragraph....my book is out in the garage & I'd have to reset the alarm...I'll list the VIN's tomorrow.
tony barnhill
Okay.....6682 LE's built "from March 1979 {car number 492071), the last Californian car was 500344 (December 1979) and the last Federal car of all was 523000 (August 1980)". Just look at the last 6 digits of your VIN.
Can't really tell by LE options as some PO's have added them to other cars.....however, all LE's were black & the black painted by the factory had a tiny bit of metal flake in it where aftermarket blacks do not..so, it's easy to see if it's the original paint.....the LE front spoiler - black hard rubber, not thin fiberglass) - goes on over the valance, not in lieu of the valance.
Joe Reed
But....there are over 30,000 cars in that VIN range, and only 6682 were LEs, so it's still possible that a car in that VIN range was converted into a bogus LE. Unless, of course, the original color is black - that was only used on the LEs.
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
