MGB 1980 MGB Roadster . . . Restoration Progress
  • Thread starter Deleted member 8566
  • Start date
Deleted member 8566
I just wanted to get on and introduce myself. My name is Justin and I'm new to the MG world. I recently purchased a 1980 to restore. I will post pictures of everything so far. I know at this point that I need a new cylinder head and I need to rebuild the block. So if anyone has a good cylinder head they want to sell for a good price, get in contact with me.
To see pictures go to this link:
MY MGB
tony barnhill
Great Pumpkin - R.I.P
Re: 1980 MGB Roadster . . . New to the MG world
JUSTIN!! Glad you made it over here....yep, for the money, looks like you got a good one!
Deleted member 8566
Thanks Tony, yea the car cleaned up well after sitting so long, now to try and get it running.
PAUL161
Welcome to the BCF Justin! It's a great group. Much activity, not inactive like the other forum you were on. Of course, there are a few here that gets a little goofy at times.
I won't mention any names though.
Deleted member 8566
So today I started to disassemble the engine. I haven't got very far, just took off the valve cover, the thermostat housing, and unbolted the manifold from the head. I still have to unbolt it from the exhaust, but it seems rusted on and I'm quite sure that they haven't been loosened in about 30 years, I expect that to be a bit of a feat. The good news is, that what I thought to be a cracked cylinder head doesn't appear to have a crack, externally that is, so that is good news for me. Tony, I will be in touch very soon to ask you your advice on this. I do know that I will be having to rebuild the bottom, which I don't exactly how to do this, but Tony has talked me through a good bit and with advice and some parts from him I think I will pull through. I also will need to think about rewiring some things. Hopefully I can get some help here on that, either by someone in my area or pictures that show what it should look like versus what I am working with, and that is where I am right now.
As I continue, I will post pictures on my web page of the progress.
tony barnhill
Just pull the whole intake/exhaust up tight against the inner fender & tie it with some wire for right now - or until you get the engine out & can more readily get to it because you are going to break a couple of the studs in that exhaust maifold (they can be replaced)
Deleted member 8566
Thats a great idea Tony, thanks, also, I'm having a real fight to get the bolts loose on the head, any suggestions?
tony barnhill
Get some PBX Blaster & spray on them & wait a half hour....then use a 1/2" breaker bar.
Jarhead
Nice looking ride Justin. Be sure to exercise lots of patience! I bought my last B several years ago and drove it for a few years before I decided to tear it down. Of course I had to get it running first. It gave me a little time to decide what needed replaced and what was okay. Tony and the rest of the BCF will prove to be invalueable.
Good Luck!
Deleted member 8566
I just wanted to come on here and thank everyone for all their help and advice, especially Tony, this is a learning experience for me and all the help and advice is greatly appreciated.
Deleted member 8566
UPDATE:
Just wanted to update on the car. I finally managed to get the cylinder head off, in am going to be working on unbolting the engine and getting it out in the next few days. I'll be posting pictures soon I hope. If there are any MGB folks in the Atlanta area, especially near the Kennesaw/Acworth area, please let me know, I would love the help and insight.
Bob Claffie
Nice looking auto. You are lucky to get one that appears sooo rust free. Mechanicals are a walk in the park compared to fussing with a rotted body/chassis. Best of luck, Bob
Deleted member 8566
Thanks Bob, yea the body is virtually rust free, minor spot on the passenger side dog leg and a little on the floor boards, but nothing major at all, the mechanicals and wiring will be a hassle though. But you're right, better than body work.
vping
Bronze
First time noticing this thread. Car looks real good and no better place than here to be if your are DYI. Lotsa good folks and advice round here. Good luck with it.
Platinum
Welcome, Justin! Good lookin' example you found.
...'cept for that German coil. :smirk: :devilgrin:
tony barnhill
Justin - just got home from overnight trip - will call you tomorrow.
Deleted member 8566
UPDATE:
I plan on getting the engine out this weekend. I'm going up to Chattanooga and going to bring back my girlfriends dads engine lift and hopefully get the engine out of the car. Since I'm stuck on going further with any mechanicals, the next step was to remove the dash and start to fix some of the shorts in the wiring harnesses, so today I got the gauges and old dash out. I will post pictures on my site soon, so keep checking back!
tony barnhill
Justin - Just looked at your photos....a tip for the next time: you don't have to remove the hood to pull an MGB engine/transmission......remove the hood prop, attach a piece of string to the front of the hood & pull the hood straight up, then tie the other end of the string to the back bumper or tailpipe.
Deleted member 8566
I figured I could do that Tony, but the hood needs to be replaced anyway so that is why I took it off.
Deleted member 8566
UPDATE:
Engine is unbolted and the lift is in place ready to pull it out. Also I went ahead and took the dash out so that I can work on wiring and replacing the dash with one not cracked.
Pictures are up on my site.
C MGB 1980 MGB Roadster Tyres UK MG 0
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
