For Sale 1980 MGB - frame off restoration 1,700 kms ago
J
Jason_Lee
This one of a kind fully restored 1980 MGB has been through a rotisserie, frame off restoration by the previous owner 1,700 kms ago to represent the earlier chrome versions of the classic MGB. This rare Canadian car is one of the last ever built. Additions such as chrome wire wheels, grill, mirrors, bumpers and trim finish off the look of this classic piece of art. The sought after O/D transmission and new Weber double barrel carb makes this beauty drive like a dream. Includes custom microfiber car cover & black tonneau cover. Over $25,000 of work was done to this beauty at 100K kms. There are only 103,550 kms on this original car.
Absolutely no work needs to be done to this car. Oil changes done twice a year and stored indoors. This car has NEVER seen a drop of rain since restoration. Owned and serviced by car enthusiasts. With a recent newborn in my family, I am unable to make time to enjoy this beauty and is now available for new ownership.
Car is stored in Thornhill, ON and will come out to Toronto once the weather warms and the salt has washed off the roads.
Asking: $16,800
More pictures or showings available by request.
Engine:
Engine #18V892AEXXXXX422
Equipped with an original equipment 1800cc engine rebuilt by Tom Haines – British Cars.
Has been fitted with a new Cannon 2892 aluminum intake manifold.
Has been fitted with a new Webber 2 bbl carburetor
The oem Lucas ignition distributor has been restored
All components are intact.
Is clean and detailed.
Under hood:
All panels have been stripped and repainted to match the exterior.
The hood has been fitted with gas restraint struts.
Has been fitted with new molded hoses.
Has been fitted with new drive belts.
Has been fitted with a new alternator.
Has been fitted with a new radiator.
The original electric cooling system fan has been retained.
Has been fitted with a new chrome plated rectangular air cleaner.
The power brake master cylinder and booster have been professionally restored.
Has been fitted with a new reproduction throttle cable.
Has been fitted with new 7mm silicone ignition leads.
Has been fitted with new braided stainless steel oil lines.
Has been fitted with new Tri-Mil stainless steel exhaust headers.
The oem wiring harness has been restored.
Has been detailed to “show” quality.
Transmission:
Equipped with the original equipment 4-speed transmission with O/D.
Has been cleaned and resealed.
Differential:
Equipped with the original equipment differential.
Has been resealed and heavily undercoated.
Underbody:
The floor pans and chassis sub frame have been heavily undercoated.
Front and rear suspension appears to be original and in good condition.
All wheel brake components have been replaced.
Has been fitted with new brake lines and hoses.
Has been fitted with a new single exhaust system.
Has been fitted with a new 12V battery.
All components are intact and in good condition.
Clean condition.
Interior:
The seats have been reupholstered using brown vinyl covers.
Has been fitted with new door panels and armrests.
The original dash pad has been retained in good condition.
The SPS aftermarket push button era radio am/fm radio has been retained.
Has been fitted with a new brown reproduction carpet
The trunk has been cleaned, painted and detailed.
Has been fitted with trunk lid gas struts.
Customizing/Restoration:
Has been disassembled, stripped and professionally repaired where necessary.
Has been fitted with new reproduction front fenders
Has been fitted with new reproduction quarter panels.
Has been fitted with a new reproduction hood (bonnet).
Has been fitted with a new reproduction trunk lid (boot).
Has been fitted with new “early” chrome bumpers.
Has been fitted with a new “early” grille and surround molding.
Has been fitted with new reproduction body side moldings.
Has been fitted with a new reproduction rear view mirror.
Has been fitted with a new radio antenna.
Has been fitted with new weather stripping, gaskets and seals.
Has been fitted with new badging and script.
Has been repainted to its present colour using dark green acrylic base clear coated.
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
