Spitfire 1980 Spitfire Coil Spring Replacement
wbdvt
Hello,
I am replacing all the shocks, so I figured I would replace the original coil springs at the same time. The new ones are one inch shorter than the originals and a spacer kit with 2 sets of 1/2" spacers included.
My question is on the pros and cons of lowering the front by 1" or 1/2" or use all the spacers to restore to original height.
Thank you in advance for feedback.
eejay56
I autocross my 78 Spit. I have cut down GT6 springs that lower the front about and inch. I also lowered the rear by 3/4 inch. The lower center of gravity gives a definite improvement in handling. I think the looks are improved too. The cons would be reduced ground clearance so you have to be careful going over speed bumps and steep driveways, and getting a jack under the car can be difficult. I also have TR7 alloy wheels and I've noticed some contact between the wheel rim and the upper A arm if I crank the wheel all the way in reverse. Triumph guru Kas Kastner recommends a height of 3" at the front crossmember in the Spitfire Competition Preparation Manual. YMMV, it depends on how you want to use the car.
W
wbdvt
Thank you Eric. This is just a drive around town and trips with top down type of car. No racing and not a show car by any stretch of the imagine. Just fun to drive to the local brewery! (Long Trail)
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
W Spitfire ZS carb on 1980 Spitfire Triumph 11
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
B Spitfire 1980 Spitfire engine block color Triumph 14
J Spitfire Spitfire 1980 intake question??? Triumph 7
hondo402000 Spitfire 1980 spitfire needs a home Triumph 0
RickAnderson Spitfire Looking at a 1980 Spitfire 1500 - Questions Triumph 8
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
BobHaskell MGB 1980 Catalyst sticker MG 0
M For Sale 1980 MGB for Sale MG Classifieds 2
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB 1980 Starter Relay & running problems MG 14
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
N "Ole 19" Freddy Baker 1980 win article?? Jaguar 1
1 1980 Panther Lima restoration project Other British Cars 11
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
AngliaGT .1980 Honda Accord Spotted 4
S Wedge 1980 TR8 BULB Triumph 3
L Advice for cleaning/painting 1980 rubber bumpers MG 8
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
AngliaGT 1980 Bonneville T140 British Motorbikes 9
A Wedge 1980 TR7 Brake master Question Triumph 5
