Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire
wbdvt
Hello,
I was just trying to get my car thru inspection and my mechanic says that the car is missing the rear sway bar. I just bought the car 2 months ago and have been doing some things to it in my garage so it really hasn't been driven. But that said, I have looked in the Haynes manual and can not find a rear sway bar. I find radius rods or arms.
So is there supposed to be a rear sway bar? Can someone send me or links to pictures of the rear suspension of a 1980 Spitfire?
Thank you all in advance and to those in the US..Happy Thanksgiving!!
BRSLimited
Spitfires don't have a rear sway bar. Having one would actually make the jacking problem more severe. There are camber compensators or Z bars that the racers use to help tame the problem.
Don_R
My 73 doesn't have a rear swaybar...and as I recall that holds true for the 1980 model....
I'm sure Andy or someone will be along to confirm or correct me.
Andrew Mace
Right, Don! Nothing there originally and no need for one unless you're looking at a highly modified track car (which likely as not wouldn't still have the rear 'swing-spring' regardless). This section of the Canley Classics web site shows various components of the rear suspension, if that helps any.
71MKIV
what the ding dong? You need a rear sway bar to pass inspection? Spitfire's never had one. Time to find a different mech...person to inspect the car.
R TR6 Rear suspension droop restraint Triumph 0
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
M Creaking rear suspension Austin Healey 13
S TR4/4A TR4 front and rear suspension Triumph 8
B Support bracket for the rear suspension damper link Austin Healey 5
H Post-War Other Herald rear suspension lower block installation Triumph 3
R Rear quarter elliptical suspension changing Spridgets 12
P TR6 Rear suspension noise Triumph 3
doc50 TR2/3/3A rear suspension / towing... Triumph 9
P TR6 Uneven rear suspension Triumph 8
J TR4/4A TR4AIRS Rear Suspension Questions Triumph 2
drooartz Tools needed to remove front & rear suspension Spridgets 24
C AH 100 Best Options for front and rear suspension? Austin Healey 9
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
G MGB New questions...Front and Rear Suspension MG 10
sail Finally got rid of the noise in rear suspension Triumph 0
blumagnet rear suspension squeaks Spridgets 18
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
I BN1 Rear Suspension Austin Healey 0
P The Rear Suspension Triumph 36
A rear suspension Triumph 1
M Rear Suspension Problem? Spridgets 16
D Rear Axle and Suspension Paint Austin Healey 9
J Spitfire Spitfire Rear Suspension Triumph 8
M Rear Suspension Pins Austin Healey 1
frankenstang57 Spitfire Spitfire rear suspension problem Triumph 15
TRclassic3 2500M rear suspension TVR 5
mikecyc72usa Monday rear suspension fun Triumph 8
bugedd Rebuilding BE rear suspension Spridgets 8
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
texas_bugeye Odd rear suspension Spridgets 8
J TR4/4A TR4 rear suspension Triumph 8
S TR6 Rear suspension TR6 Triumph 8
1 Rear Suspension Photos Spridgets 12
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
T Reference pictures of Bugeye rear suspension Spridgets 2
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
A Revington Rear Suspension Upgrade Feedback Triumph 0
tahoe healey Rear suspension Latest Austin Healey 18
tahoe healey torque on rear suspension Austin Healey 1
1965_MGB Brit-Tek Rear Suspension Kits. Any Experience? MG 2
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
B Spridget Rear Suspension. Racing 2
tr7andtvr Spitfire Spitfire rear suspension part needed??? Triumph 3
philman Wedge wedge rear suspension Triumph 8
Cottontop Another Rear Suspension Question Austin Healey 10
N Differential and rear suspension Austin Healey 113
