MGB Rear Suspension Damper Link Arm
Davo1969
Hi all - greetings from UK, recently joined and a novice mechanic on partially restored 1969 MGB Roafster.
I am trying to replace rear lever arm shock absorber and had to remove both shock, link arm & link plate (as existing shock absorber arm had come off splines).
I have eventually managed to get old shock arm off link (top end of link arm) - but I am having real difficulty removing the bolt on the link plate connecting to bottom of link arm (ball joint). I cannot get nut off as just spins along with inside of ball joint - please can anyone assist/any tips?
Thanks
David
YakkoWarner
I just did two of these in the past couple weeks (was able to remove the link arm while the car was up on jackstands so I did not remove the link plate from the leaf spring). What I did was to get a small bottle jack and apply upward pressure on the ball joint (but not enough to lift the axle from the jackstand). This wedged/deformed the ball joint enough that I was then able to turn the nut and remove the arm from the link plate and since it is being replaced anyway no need for concern over the condition of the old ball joint. If the link plate is already off the car, then coming up with some way to put adequate pressure on just the ball joint may be a trick.
Platinum
Welcome, David.
If the ball is turning in the link, the link is scrap and will need replacing so the only way to get the nut loose will be to pry/cut the link from the stud and use a pipe wrench or Vise-Grips to clamp the thing to undo the nut. Nasty job, a bench vise makes it easier.
B Support bracket for the rear suspension damper link Austin Healey 5
R TR6 Rear suspension droop restraint Triumph 0
Healey Nut BT7 Rear Suspension Austin Healey 15
M Creaking rear suspension Austin Healey 13
S TR4/4A TR4 front and rear suspension Triumph 8
H Post-War Other Herald rear suspension lower block installation Triumph 3
R Rear quarter elliptical suspension changing Spridgets 12
P TR6 Rear suspension noise Triumph 3
doc50 TR2/3/3A rear suspension / towing... Triumph 9
P TR6 Uneven rear suspension Triumph 8
J TR4/4A TR4AIRS Rear Suspension Questions Triumph 2
drooartz Tools needed to remove front & rear suspension Spridgets 24
C AH 100 Best Options for front and rear suspension? Austin Healey 9
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
G MGB New questions...Front and Rear Suspension MG 10
sail Finally got rid of the noise in rear suspension Triumph 0
blumagnet rear suspension squeaks Spridgets 18
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
I BN1 Rear Suspension Austin Healey 0
P The Rear Suspension Triumph 36
A rear suspension Triumph 1
M Rear Suspension Problem? Spridgets 16
D Rear Axle and Suspension Paint Austin Healey 9
J Spitfire Spitfire Rear Suspension Triumph 8
M Rear Suspension Pins Austin Healey 1
frankenstang57 Spitfire Spitfire rear suspension problem Triumph 15
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
TRclassic3 2500M rear suspension TVR 5
mikecyc72usa Monday rear suspension fun Triumph 8
bugedd Rebuilding BE rear suspension Spridgets 8
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
texas_bugeye Odd rear suspension Spridgets 8
J TR4/4A TR4 rear suspension Triumph 8
S TR6 Rear suspension TR6 Triumph 8
1 Rear Suspension Photos Spridgets 12
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
T Reference pictures of Bugeye rear suspension Spridgets 2
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
A Revington Rear Suspension Upgrade Feedback Triumph 0
tahoe healey Rear suspension Latest Austin Healey 18
tahoe healey torque on rear suspension Austin Healey 1
1965_MGB Brit-Tek Rear Suspension Kits. Any Experience? MG 2
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
B Spridget Rear Suspension. Racing 2
tr7andtvr Spitfire Spitfire rear suspension part needed??? Triumph 3
philman Wedge wedge rear suspension Triumph 8
Cottontop Another Rear Suspension Question Austin Healey 10
N Differential and rear suspension Austin Healey 113
