AH 100 Best Options for front and rear suspension?
christophe
The front suspension is shot on my car and I think, currently, that is where i would like to start dumping money into the car.
So,
1. Shocks: Do most people rebuild the shocks or replace them? I typically work on mid sixties muscle cars, so this type of shock is entirely foreign to me. How difficult are they to rebuild? The only parts i see for them on the Moss website are heavy duty valves.
2. Front and Rear Springs: Any particular place i should order these parts from? Does anybody make a nice street performance front coil spring, or are they pretty much run of the mill replacements all around?
3. King Pins: Would someone please explain to me exactly what the kingpin does and why it so commonly needs to be replaced?
Thanks!
steveg
FWIW - my summary take:
1. White Post or Apple Hydraulics for rebuild. Putzke's Fahrspass for the 4-wheel Bilstein kit. IMHO the latter provides a better ride.
2. Moss for front and rear springs. Never heard of any aftermarket competition springs.
3. Moss - my question would be whether the king pins or bronze bushings are worn. Randy Forbes on this list does bushings if I recall.
Also - the steering bush at the bottom tends to wear out.
Flame away.
C
christophe
Thank you for the information!!! I had white post rebuild a couple of master cylinders for me a few years ago and they are pretty pricey. I can only imagine that they charge a pretty penny to rebuild the original shocks. The bilstein conversion might be the best route. My car is so far from original that changing out the original shocks for a conversion set should not be seen as blasphemy.
So generally it is just the bushing that wear out in the kingpin and that is all?
5
57_BN4
If you don't mind the cost, the telescopic shock conversion kit will give more modern performance. You'll need to disable the damping function in the original shocks and preferably have the fulcrum bushings remade in plastic to tighten them up. Shocks can be DIY rebuilt if you are mechanically inclined and have a lathe available. Some of the exchange rebuilt ones have difficulty with oil leaks.
You'll probably want to change out the bushings in the lower A arms if they haven't been done recently (can be a ***** of a job) and also the upper/outer arm bushes which can be replaced with a set of "negative camber" offset ones to improve geometry for radial tires. The thrust washers in the kingpins are available as needle roller bearings now which gives a slight decrease in steering effort.
Springs are usually pretty hard to begin with, I'd consider staying with the originals unless they are sagging or you want to change the ride height. Uneven front wheel arch heights are usually caused by sagging rear springs.
Get your stub axles crack tested too if you have them off to redo the king pin bushings, they are often cracked.
Andy.
ahealey1004
I agree with Andy- while I haven't bought one of the Putzke kits yet, I spent some time around Udo at the Salt Flats last year as he worked tech for Steve Pike's streamliner record attempt, and he's a great guy and very knowledgeable. The kit looks very well engineered, and it's entirely reversible should originality become a desire in the future. And while you're rebuilding your front suspension, I found that replacing my tie rod ends and center link helped reduce steering effort, as my old ones on my bn4 were very tired. And check your idler arm for play- it can make a knocking sound over bumpy roads and leave you scratching your head to find the source. And rather than searching for performance springs, or cutting coils, just add some 1" lowering spacers between the lower spring pan and a-arms. I've done it and like it. Good luck!
John Turney
Shocks: You've already received a couple of good recommendations for rebuilding shocks.
Springs: Competition springs, other suspension bits and brakes are available from https://www.bighealey.co.uk/. Not cheap, but excellent quality. Other than those, the standard springs from Moss are fine.
King pins: Unlike more modern cars, Healeys don't use ball joints in the front suspension. Except for the steering joints, all Healey suspension joints rotate in one axis only. The king pin allows the stub axle and front wheel to rotate left and right. There are sleeve bearings above and below the stub axle that often wear, but should be checked before just replacing them as they may not need it. Each lower A-arm has a bushing at the outer end that rotates up and down on threaded shafts at the bottom of the king pin. The upper A-arms have a bushing at the outer end that rotates up and down at the top of the king pin. As Andy said, that upper bushing can be replaced with an eccentric one to allow camber adjustment. That's a quick explanation, and others may say "You got it all wrong!"
C
christophe
Great replies! And John, thanks for taking the time to explain the kingpins! It makes perfect sense now. For me, looking at a picture of the parts, or at the parts assembled and covered in almost 60 years of grease, only goes so far. Until I actually disassemble something and have it laid out in front of me, I sometimes have a difficult time comprehending how it functions.
If i can get the stock units rebuild for around 400.00, then i will probably stick with them instead of using the bilsteins. There are many parts of this car that need attention and doing expensive upgrades can quickly take this from a reasonable rebuild to a money pit.
PSJ
Second vote for Peter Caldwell. I have rebuilt shocks from Peter on my MGBGT and on my Dad's '53 100. Good value, good service.
dcarlg
Third vote for Peter Caldwell. He sent me 4 rebuilt shocks, I sent him my old ones as cores. Easy and affordable.
H Best Weight Oil for My '59 100-6? Austin Healey 3
drooartz Best $100 yet Spridgets 18
F 100 4 ONE OF TEN BEST Austin Healey 4
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
