TR2/3/3A The steering box again?
karls59tr
Bronze
When I rebuilt the steering box a few years the bearing was unavailable. The PO had swapped in a more substantial looking bearing of the same size. I see that Moss now carries them. Anyway when I installed the box and set everything up it all works properly but the steering wheel sits about 15 degrees off when I'm driving going by those banjo spokes on the wheel. There was a fair bit of play in the steering wheel so I tightened up the adjuster and that decreased the play but then the steering was too stiff so i backed off the adjustment a bit and now there is a couple of inches of play still there which I can live with. My question is :Can I remove the steering wheel and reposition it so as to get rid of that 15 degree cant of the wheel banjo spokes or would that not solve the issue?
Also in regard to the Revington spring loaded steering box adjuster. Wasn't there a thread on here that indicated it might not really be effective in holding the adjuster pin down for some reason? Anyone here using that Revington steering box top and what do they think of it.
Karl
PS Anyone heard from Randall?
PAUL161
What car model? PJ
TR-3rg
I rebuilt my steering box last year. My steering wheel was off, so I slide it out of the coupler and rotated it. The stator tube, at the steering box, will have to be loose. It was really easy. If you still have a problem with slop in the wheel, make sure the steering wheel nut is tight. It can be staked from the factory, but still loose enough to wiggle. Mine had an 1" of slop until I retorqued it.
Prior to all of this, I replaced the silent block bushings with the Teflon / stainless steel bushings (ARE). They work well. I had an adjustable steering box cover from BFE but is did not really help. The Revington one has good comments in the British Triumph Forums, but I have no first hand experience with it. Revington makes a great set of steering arms to correct the Ackermann geometry. If you are running wide tires, its worth it. I have 195/60-15's and it is noticeable.
Good Luck, Roy
CJD
The answer is Maybe. The worm is cut so it has a center position with no lash, or play at all. In fact, it actually has a small amount of negative play, or drag. This way the steering does not wander while you are trying to go straight. Once you turn the worm out of straight, there is actually a lot of play...but you don’t notice it. The steering geometry is set up so the car wants to track straight ahead, so you have to hold the car in a turn. Therefore the play is there, but the steering geometry is holding the pin against the worm, so it is never felt to the driver.
Back to your question. Your steering wheel MUST be installed so it is centered on the center of the worm. American cars all mark this position...but I have not seen any marks on my British cars. If your wheel is installed off from the worm center, then it should be removed, centered on the worm, and reinstalled and then I recommend marking the location for future reference.
Telling center is a can worms (no pun intended). The only real way to tell is before you have the steering arm attached. You count the total rotations and then find the center. After the gear is installed, the suspension may trick you...for example. If a bozo installed the steering wheel in the wrong position, they will unwittingly adjust the tie rods out of whack to center the steering wheel. Now, if you count rotations, the steering will be limited in one direction...and counting the total turns will be thrown off.
When properly adjusted, the gear will have a very slight drag as you turn the wheel past center. The steering wheel must be centered on the drag. Then you adjust your tie rods to center the car steering. A quick check to see if you may have the wheel installed off is to measure the tie rod lengths. They should be the same length within your ability to measure them. If they are noticeably different, then you’ll need to start from scratch and center your steering.
K
karls59tr
Bronze
Thanks for clarifying the issue. Do you know if there is an actual torque value for the steering wheel lock nut?
Karl
sp53
One thing to watch for is if you have a split column. When attaching the wheel, make sure there is enough end play on the top outer shaft or leave the out shaft loose so it can slid down when tighten the wheel down on the tapper of the rod or the wheel will not bottom out on the tapper. It will hit the column and be held away from tightening down on the taper of the actual shaft and the wheel will come lose after time. The shaft is tapered and people usually tongue them at 30lb. There should be some punch marks on the nut and wheel. I think the balance number for the tie rods is around 7-3/8 inches center to center both sides. Then fiddled perfect.
steve
Herk
If you have the 2-piece column there should be a punch marked "dot" between the coupler splines and the bushing. The dot should be straight up with the steering straight ahead. This indicates the high point on the cam. The pittman arms hould also point directly to the rear.
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
K TR2/3/3A Steering box fluid again.... Triumph 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
simon1966 Steering box lubricant Austin Healey 17
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
K TR2/3/3A Steering Box Triumph 2
M BJ8 Steering box removal Austin Healey 8
T Steering Box Pinion Seal [?] Spridgets 1
S TR2/3/3A steering box sealer Triumph 9
