Steering box BJ8
barnman
Good afternoon, anybody any idea how much lubricant the steering box and idler hold.
I am rebuilding the box and need to buy an appropriate amount.
Thanks in anticipation.
steveg
A quart/liter should do it; a pint won't. If you're buying Penrite, 2 bottles.
When you're filling the steering box, be sure to turn the steering wheel lock to lock a few times so it settles in properly - otherwise it will appear as full when it's only half full.
I found it convenient to heat up the grease in the microwave, then use a turkey baster to inject it into the box.
Healey Nut
If you're using corn head grease then its a cartridge and a half or thereabouts .
steveg
The John Deere Corn Head grease is easiest to install with a gun with a flex hose and grease injector needle. The needle probes down into the box so you're filling it up from the bottom up.
Installing from a squeeze bottle such as Penrite is more difficult because the grease tends to collect at the top and overflow out the hole.
Be sure to turn the steering wheel such that the box's internal arm is out of the way of the hole or it'll tend to block the filling, causing overflow.
M BJ8 Steering box removal Austin Healey 8
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
Randy Harris Steering box on my BJ8 - filled with grease? Austin Healey 27
N Leaking steering box on BJ8 Austin Healey 4
N BJ8 steering box leaking oil Austin Healey 11
H 1966 BJ8 Steering Box Leak @ Wire Compression Nut Austin Healey 7
S Steering Box Rebuild - BJ8 Austin Healey 6
S BJ8 Steering Box Peg Replacement Austin Healey 3
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
