BJ8 steering box leaking oil
NIB
Just did a service on the car today. I checked the steering box for oil and couldnt see anything. Filled it up with around 0.1 gal of oil, quite alot. Shortly after i discovered why, oil leaks from the cables that goes to the steering wheel. I started to clean the area and was a bit surprised to see its not from the olive seal/ brassnut it comes, but from within the tube along the cables. Is the tube cracked or what could be the error?
I used EP90 oil.
Keoke
Is the tube cracked???????
Sore cold be. However, cracks that low down are not common. Maybe the rubber bumper that fits about midway down on the outside of this tube was missing and it was allowed to flex too far.---Keoke
N
NIB
How is the tube attached? I thought it was supposed to be removed at the steering wheel, but i was able to pull it out from the steering box atleast 3 inches.
The car was originally with adjustable steering column and now has a moto lita steering wheel, does that matter?
IanIrving
Hi Nib
If the nut and seal are ok and tight you shouldn't be able to pull it out from below. Is the seal actually there? maybe there's just the nut and no seal or maybe it isn't the right seal. You can't move mine unless you loosen the nut and olive, then it can be moved.
Ian
richberman
NIB,
It pulls out from the bottom, once the nut/olive are removed. Just be careful to tie a string to the wires so replacing the wires is easier. On an adjustable column, there are two tubes which fit together via slot/notches about 12" from the steering wheel. The longer (stator) tube is a straight shot down and through the steering box. The wires go through it for the horn and turn signals and the nut/olive keep the oil in the steering box.
You may also have a leak from above the Pitman arm. There is a rubber O-ring which creates the seal around the steering column proper, which may need replacing. Randy Forbes has some good pictures of it here. https://www.spcarsplus.com/gallery3/index.php/reMKIII/IMG_2812
I few pictures before this shows the moto-lita end.
If you scroll down to the section on trafficators here https://healey6.com/technical.htm, there are good articles on replacing the stator tube as well as what you'll find at the steering wheel end.
rich
N
NIB
IanIrving said:
Hi Nib
Ian
I didnt explain it very well, but its only when the nut is loose i can move the tube and the seal is on the tube, it cant be moved, it sits firmly.
I will order a new tube and seal and return here if I see any interesting when doing the job.
bob hughes
:lol:
And how long will that last surrounded in oil?
Best weld it up and grind it back, but new tube has been purchased, and probably just as well.
Still you can experiment with the old one as a spare!
Bob
B Steering box BJ8 Austin Healey 5
M BJ8 Steering box removal Austin Healey 8
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
Randy Harris Steering box on my BJ8 - filled with grease? Austin Healey 27
N Leaking steering box on BJ8 Austin Healey 4
H 1966 BJ8 Steering Box Leak @ Wire Compression Nut Austin Healey 7
S Steering Box Rebuild - BJ8 Austin Healey 6
S BJ8 Steering Box Peg Replacement Austin Healey 3
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
pkmh BJ8 Steering Wheel Refurbishment Austin Healey 4
P BJ8 Steering column support bracket Austin Healey 6
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
D BJ8 Steering gearbox Seal Austin Healey 9
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
I Repair to bakelite steering wheel BJ8 Austin Healey 5
6 Problem Removing Steering Idler BJ8 Austin Healey 9
6 How do you remove steering idler on BJ8? Austin Healey 0
6 Idler steering Assembly Problem [BJ8] Austin Healey 7
6 BJ8 Steering Wheel Chatter Austin Healey 4
7 color of steering column for BJ8 Austin Healey 2
S BJ8 Steering Idler Assembly Austin Healey 3
S BJ8 Steering Adjustment Austin Healey 3
A BJ8 Steering column strut Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
