The Idler assembly in my phase 1 BJ8 was replaced by the PO. When I was lubing the car recently, I noticed that the idler has a grease nipple on it rather than a plug. I know the Haynes manual suggests Castrol Hypoy, the same as for the steering gear box and rear axle. But I assume that since it has a grease nipple, someone has lubed it with grease at one time, probably many times since the idler was replaced years ago. My questions are: does anyone know if replacement idler assemblies come with a grease nipple and should grease be used in them? Or would I be better off still using hypoy gear oil? What about the grease that has no doubt been used before in the idler?
