TR2/3/3A Oops...Steering Box Situation
RGW
Member
In another post the other day I'd mentioned my 59 TR3A wouldn't turn to the left. The steering seemed blocked. It doesn't seem like the vertical links are bent, etc. So, I took off the top to the steering box just to have a look see.
I then sat next to the driver's side wheel and turned it by hand. As I did so, drop arm and trunion bracket (I think that's what they're called) shifted downward a bit. As I pushed them back upward to where they should sit, it seemed like the wheels were turning freely to the left (which they were not doing beforehand). This leads me to believe that the problem is in the steering box...any thoughts?
I then went to turn the steering wheel and it seems disconnected. It spins freely, without any affect on the wheels...seems like I've screwed something up...What have I done and how do I fix it?
And now for some more advice/encouragement. I've dabbled with cars for a long time, but not in a serious way. I've just acquired this TR3A...I grew up with them as my Dad was a serious sports car enthusiast (Triumphs, Healeys, MGs, and Minis), and now I'm trying to carry on the tradition, but I'm a newbie when comes to dealing with steering...I've looked into removing the TR3's apron and removing the steering box, but I start to get the heebie jeebies and feel like I'm going too deep for my skill set...Should I put on my Big Boy Pants and give it shot or should I try to find a mechanic to lend a hand?
Sorry for the long post and a million questions, but I really respect you guys and your advice.
Thanks,
GW
sp53
Yeh the peg probably lifted out of the worm gear and the worm gear is just spinning freeely. Be very careful if you put the peg down; do let it mash into the worm gear or you will chip it. Maybe consult the forum history and get some help to get the peg down and cover back on without damaging anything; stop turning the wheel without the cover.
CJD
+1. The box cannot be operated with the cover off.
To find the bind you will have to lay under the car and listen as someone turns the wheel back and forth. Watch and listen carefully. When you have a suspect, then remove the associated link to test your theory. The steering box should be near last.
R
RGW
Member
Thanks for the warnings...my main concern right now is resetting the peg and worm gear without damage. Seems like I went from bad to worse...I've researched the forum pretty extensively and can't seem to find a way to reset the peg. This morning, I'm thinking I'll center the wheels, center the steering wheel, replace the steering box plate and hope that it all seats itself...yeah, a pretty big wish, but kinda stumped for now.
Again, thanks for the help.
R
RGW
Member
Yeah, I didn't realize that the cover was that important until doing a bit more research last night and reading your quote this morning. Planning to replace the cover today but really concerned about the peg and work gear lining up. If I manage that OK, I'll do as you suggest and spend more time looking and listening.
Thanks for the help.
CJD
Just turn the steering shaft while pushing downward on the peg. When the worm aligns with the peg, the pitman shaft will drop back down into place. There are no other alignments to worry about.
R
RGW
Member
Thanks. You've given me some confidence. Hoping to get to it this afternoon.
sp53
+1 with John--- it should drop back in--- go slow and maybe if you have to push up from underneath on the bottom of the pitman arm with your hand at the big nut if needed to free the peg from the worm gear so it can move; can you take a picture? Is the peg in the pitman arm? I have seen the pegs drop out of the arm. They had worn lose and lost their press fit. I am not trying to complicate this; it should go back down. I did the same thing once.
Steve
W Jacking OOPS Jaguar 1
bugedd Heater blower wanted...oops Spridgets 8
racingenglishcars Oops, hillclimb Lotus 4
Banjo Oops.. I bored the cylinders too far... Triumph 11
Got_All_4 TR2/3/3A TR3 disassembly oops! Triumph 9
T oops... too far? Triumph 17
aeronca65t Oops! Racing 4
texas_bugeye oops stack on the wrong end Spridgets 5
L Engine Backplate Installed...OOPS!! Austin Healey 10
JPSmit Oops one more question Spridgets 17
1976Midget Oops! I did it again Spridgets 5
emann Tach Drive Gearbox - oops Spridgets 7
C Oops MG 13
RickB Found a 74 Midget - may buy it - advice? [oops] MG 9
longbridgehealey oops - forgot to attach e-bay listing Austin Healey 2
P Re: oops MG 1
P oops MG 9
beaulieu 1974 Lotus 4 door - what is it ? oops 4 seater ! Lotus 19
MattP Oops. MG 8
JPSmit Oops one more, Cooling Question Spridgets 2
Bob Claffie Oops, it's sold Sunbeam (Rootes) 1
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
